Results 1 to 7 of 7
Thread: Start up
    Jul 2016
    Las Vegas
    325
    Start up
    Since I will be doing my own startup, does Startup-Tec speed up the time when you can swim after the pool has water? I was thinking of doing the acid startup? However, does Startup-Tec eliminates the need for acid.... Also .. which is better, Jacks or startup-tec? In your opinions..
    Is there a method that speeds up timing when you can use the pool? I read the Pool School startup.. And I get the warning.. no swimming during startup... but was wondering if exceptions exist
    Cement Pond <--- build - 15K gal, 16 x 34 Rectangle, All Pentair - 520 Filter, 2 Intelliflo 2VST pumps (3hp) - 1 filter/1 water features, EasyTouch 8, Screen Logic, IC60 SWG,
    Pop-up Cleaners (Wet Deck and steps), 2 LED Bubblers, 3 LED 24" waterfalls, 5G LED Pool Light, Quartscapes Reflections Tahoe Blue plaster, Real Coral coping/deck, TF-100 Test Kit, 1766 Salt test kit.
    Jul 2016
    Las Vegas
    325
    Re: Plaster start up
    anyone?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Nothing eliminates the need for acid. You will need that for the lifetime of the pool. I would not advocate swimming during an acid startup, you'd need to wait until the pH is in a normal range between 7.2-7.8.
    Startup Tec or any other sort of sequestrant is used to prevent scale from forming while the plaster is curing. Few really understand what is happening during the hydration and curing of the plaster; using a sequestrant is not just for known metals in the fill water but also to prevent scale formation. Calcium is a metal after all.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jul 2016
    Las Vegas
    325
    Quote Originally Posted by bdavis466 View Post
    I only meant eliminate need for acid at startup. or an acid wash, because those products indicate that they pretty much reduce plaster dust.
    And I understanding not swimming during an acid startup, my questions was is the time before you can swim shortened. I guess it all depends on the PH level is what you are saying? Also, still not sure what the diff between the two products are.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: Start up
    They both are basically sequestrants.
    There is nothing that magically eliminates plaster dust. A quality application of a quality product that has been allowed to set up before exposed to non aggressive water will produce little dust. Pools that get acid washed the day following the application will have little to no dust anyway and do not need an acid startup. There really isn't anything to replace an acid wash as that is necessary to expose the aggregate and even out the plaster variations.
    This site advocates no swimming for the first month which I feel is very extreme. The plaster will be very hard 24 hours after application. So long as your swimmers are cognizant that the plaster is fresh, don't do anything reckless and the water is balanced/sanitized, I don't see why they can't swim...I sure would be.
    I may have missed it, but what type of finish are you doing?
    -Brian-
    POOL BUILD
    Jul 2016
    Las Vegas
    325
    Re: Start up
    Thank you! I am using quartzscapes reflections Tahoe - apparently the most popular in Vegas, according to the supplier...
    I am guessing and acid wash is applying a diluted acid mixture directly to a dry pool, versus an acid startup which is putting the acid in a full pool...
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: Start up
    Correct but full strength acid is used and it is usually followed by a pressure wash.
    Each plasterer has their own technique. Depending on the color, an acid wash may not be needed.
    -Brian-
    POOL BUILD
