Thread: Is My Pool Ready to Jump on the Borates Bus?
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    I've been busy converting my pool to TFP method and moving closer to BBB. 55lbs of boric acid from Duda will arrive Monday ($84 including shipping). I'm almost there!
    Currently:
    FC 4
    CC .5
    PH 7.9
    CH 275
    TA 80
    CYA 40
    BOR 1 (Looks like I need almost all 55lbs to get to 50ppm.)
    Is the chemistry inline for boric acid?
    Any other guidance?
    Thank you!
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    JoyfulNoise's Avatar
    May 2015
    13,253
    Re: Is My Pool Ready to Jump on the Borates Bus?
    Is your pH stable with a TA of 80ppm? If not, you want to lower TA BEFORE you add borates.
    Matt
    Jul 2015
    Katy TX
    90
    Ph stability has been a challenge. It would rise and I'd knock it back down with MA. Only to rise again., which is why I was switching my pump run times (from 22 hrs/day to 15 hrs/day).
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I keep my TA at 50 and with Borates my PH has stayed locked in at 7.5 to 7.6. I put 10 Oz of MA in twice this season. In prior years before Borates my PH swung up all the time. I used to put 2 to 3 gallons of MA in a season.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    The boric acid way is so much easier. I went with borax boxes and it's a lot of work.
    Solar Blanket, Well Water, Borax Added. 76
