Results 1 to 8 of 8
Thread: Polaris PB4-60 Causing Electrical Current in Pool
    Aug 2016
    Carriere, MS
    4
    Help! After turning off all pool equipment and checking the electrical current in the pool with a voltage meter our Polaris pool booster seems to be the culprit of the electrical current in the pool. From the outside of the booster pump all seems to be in tact and grounded. Polaris is operating normally when running. Any ideas on what could be causing this? Also we have had a few thunderstorms in our area since we last swam. Thank you!
    Inground Salt System Pool
    25,000 gallons
    Polaris PB4-60
    Intellichlor Chlorine Generator
    Stra-Rite Pool Pump
    38,524
    Re: Polaris PB4-60 Causing Electrical Current in Pool
    Seeing current requires 2 problems. 1. Improper bonding of the pool, water, and equipment. 2. Stray current
    Appears you have identified the cause of number 2, but if the bonding was correct, you would not be able to measure a potential in the pool.
    Aug 2016
    Carriere, MS
    4
    Thank you for your response! Def going to look into this!
    25,000 gallons
    Polaris PB4-60
    Stra-Rite Pool Pump
    Apr 2013
    Sacramento, CA
    2,769
    Until you have an electrician come out I would disconnect the wires to the booster pump. The recheck if you are still getting current in the pool.
    This video explains how to check whether or not the pool has effective bonding.
    Swimming Pool Equipotential Bonding [Part 3 of 3, Testing], (28min:39sec) - YouTube
    Aug 2016
    Carriere, MS
    4
    Quote Originally Posted by gwegan View Post
    Thanks we def will! Very informative video!
    25,000 gallons
    Polaris PB4-60
    Stra-Rite Pool Pump
    Why do you think that the booster pump is the source of the electricity?
    If the booster wires were shorting to ground, the pump probably would not work and would trip the breaker.
    In any case, don’t allow anyone in the pool until an electrician checks it out.
    Support the site
    Aug 2016
    Carriere, MS
    4
    Quote Originally Posted by JamesW View Post
    In any case, donít allow anyone in the pool until an electrician checks it out.
    It only appears to electrify the water when it is running???? Have called a electrician to check it out. No swimming until then. This happened about 2 years ago with the other booster pump as well but the pump wasn't working...so we replaced it. But if I'm understanding everyone correctly no matter what equipment is having issue it should never equal a shock in the pool. Is that correct? And is that a bonding issue?
    25,000 gallons
    Polaris PB4-60
    Stra-Rite Pool Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, that is a bonding issue.
    More here, Pool School - Bonding vs Grounding
