Thread: How much sand ??
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    How much sand ??
    I have an older Hayward sand filter and it seems to have lost a bit of it's performance. I opened it up to take a look at it and I'm wondering if it has enough sand in it.
    There's no info on the filter but I'm pretty sure it's a S240 that's supposed to hold 300lbs of sand.
    Plenty of room to add two or three bags but wondering if they're needed and or will help at all
    Getting ready to do a deep clean.
    Solar Blanket, Well Water, Borax Added. 68
    May 2016
    Marion, NY
    41
    Re: How much sand ??
    I'm not an expert by any means, but I just filled mine a week and a half ago. My pool builder told me 10 to 12 inches down from the top was the right fill level. level. Mine's a little bit different with the multi port on top comma so I'm not sure how that relates to your filter.
    24' round Radiant Metric, Partial IG install, 14000 gal, Circupool RJ30 SWG, Hayward Super VS, 250#Sand Filter, TF100 test kit.
    Marion, NY
    Fill to about an inch below the edge.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Well I dropped in the 3 bags (150lbs) of sand and I did end up close to an inch from the top. I think it was low on sand but I'm not seeing or feeling any of it sitting on the bottom
    Will likely take it apart this fall or coming spring and check the laterals just to be sure. Too nice a day so I cleaned it, added the sand and I'm
    Probably lost some during backwashing.
    Support the site
