Results 1 to 11 of 11
Thread: Getting my FC right
    Aug 2016
    Burleson, TX
    6
    Getting my FC right
    I am a new pool owner and recently refilled my pool. I'm trying to get the water balanced. I bought the recommended test kit, but can't seem to get the FC up. What is the recommended level of FC? Should I be pouring bleach straight into the pool? I added conditioner a little over a week ago to raise the CYA, but can't seem to get either raised to recommended levels. Should I be adding bleach every day? If so, approximately how much? It seems like I have been putting a lot of bleach in my pool.. Thanks for any help.
    10,500 gallon in ground plaster with attached spa
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Getting my FC right
    Hi, welcome to TFP! How did you add your conditioner? If you have a sand filter did you backwash after adding conditioner? You can see the recommended levels on the FC/CYA Chart. Pour the bleach slowly in front of a return while the pump is running. Read through ABCs of Pool Water Chemistry for basic information on pool chemistry. PoolMath will show you how much you need to add.
    Love TFP? Become a
    TFP Supporter!
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Please post you test results like this:
    FC
    CC
    PH
    TA
    CH
    CYA
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    More here about adding chems to your pool, Pool School - Recommended Pool Chemicals
    Aug 2016
    Burleson, TX
    6
    I used the sock method described on this web site to add the conditioner in front of the return. I have read quite a bit on the website and slowly starting to undesrstand the process. I just did all my tests and I got a reading of 0 FC. I put in 34 oz. of bleach about three hours ago based on the pool math. I had a reading of .5 FC this morning. Here are my numbers:
    FC 0
    CC 0
    Ph greater than 8
    TA 120
    CH 100
    CYA my guess is 20. The water is cloudy, but does not cover the black dot.
    i haven't messed with anything yet except for the FC and the CYA. Why would I have 0 FC after putting all that bleach in this morning?
    Jul 2009
    Houston, Texas
    9,377
    You need to add some MA and get the pH down to around 7.5 Since 8.0 is the top of the scale your pH may actually be higher and take a couple of doses of MA to get the pH down where it needs to be. How does the water look?
    What is your water source? What FC level are you trying to reach? What strength bleach are you using? 34 ounces of 8.25% bleach would only give you 2ppm of FC.
    Love TFP? Become a
    TFP Supporter!
    Aug 2016
    Burleson, TX
    6
    My water source was just tap water from Bethesda water. I am trying to get to a FC of 3. Is that typical? The bleach is 10%. The water looks fine.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    With low CYA, it's not unusual to lose 3-4 ppm of FC per day to sunlight. And that's without any algae in your pool. Get that CYA up to at least 30 and then see what happens.
    But you will still have to add some chlorine daily.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2016
    Burleson, TX
    6
    Why does my ph raise so high and quickly
    I can't ever seem to keep my ph down at the right level. I will get them down and check a week later and it is well over 8. Please advise.
    30,403
    Re: Why does my ph raise so high and quickly
    What is your TA? Tell us how you chlorinate. We need to know a lot more to give you a reasonable answer.
    30,403
    Please keep your questions under the same thread.
