Thread: Timer not working
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    Exclamation Timer not working
    Trying to upload photos from phone - hope they did
    Timer is "ticking" but not turning gears so not functioning to turn dial and turn pool on and off
    Any ideas short of call to electrician ?
    I can balance my water but that's where my know how of pool maint pretty much ends
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Timer not working
    The printed thing that says "motor check" at about the 1 o'clock position, look thru there with a flashlight to see if the plastic gears are moving. I guessing they aren't. If not, you need to replace the motor Easy to do.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Also check to see if it is stuck in the pull out position. Mine did that once after I pulled it out to set the time and it got stuck in the pulled out position. I had to make sure it went back in.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
