Results 1 to 10 of 10
Thread: Buy salt testing options with TF-100 order?
    Sep 2015
    Atlantic Beach, FL
    70
    Good morning, pool people!
    Iím about to order my TF-100 test kit, and I see some optional items listed for salt testing. Do you recommend getting the Taylor K-1766 Salt Test and/or Aqua Chek Salt Test Strip options? Or will the basic test kit itself be sufficient?
    8K gal 13'Wx19'L IG kidney. 3.5' to 5'6" depth. Pentair: Ultratemp 120 heater/chiller; Intelliflo 2 VS pump; Intellichlor IC40 SWG; cartridge filter; EasyTouch controller. 3 wall returns, 1 skimmer, 1 cleaner line. Tremron Oak Run coping and pavers. Noble Tile Toscano waterline. Marbletite's Freestone pebble in St. Thomas. TF100 and K1766 test kits.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Buy salt testing options with TF-100 order?
    Looks like you'll need/WANT the Taylor K-1766 test for salt.
    38,237
    I agree, get the Taylor salt test. SpeedStir too if you can swing it
    Sep 2015
    Atlantic Beach, FL
    70
    Thanks! TF-100, K-1766, and SpeedStir it shall be.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    I'm glad I got the K-1766. Easy test with obvious endpoint, and you can make the kit last a long time because the test is infrequent.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Sep 2015
    Atlantic Beach, FL
    70
    Thanks!
    May 2012
    Toronto, ON
    463
    Can you just use the sensor on your SWCG? My Jandy Aquapure 1400 gives a salinity reading on the LCD screen.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    JoyfulNoise's Avatar
    May 2015
    13,173
    Quote Originally Posted by wayner View Post
    They are not terribly accurate and the Pentair line (IntelliChlor) have very poor temperature compensation. The Hayward line uses multiple cell parameters (current, voltage and temperature) to infer salinity levels and is probably the most accurate of all. However they are all about +/-400ppm. The K-1766 test is +/-200ppm for the standard test protocol (10mL water sample) but can be more accurate if needed by simply using a larger sample size (+/-80ppm for a 25mL sample).
    Finally, the K-1766 is a true chemical measure of chloride content while all other methods are proxy measurements and suffer from interferences.
    Matt
    May 2012
    Toronto, ON
    463
    What do they do? Infer the saline content from the conductivity/resistivity of the water?
    May 2015
    13,173
    Yes. SWG's act like electronic TDS probes, they measure conductivity. But conductivity can be affected by any ion in solution, not just Cl- . Strips rely on capillarity to determine salinity and, once again, that is subject to interference. Hydrometers use differences in specific density of saline water but it is highly temperature dependent.
    Matt
