Thread: New pool owner
    Aug 2016
    Chester
    2
    New pool owner
    Test kit is K-2006
    These are my results from testing.
    FC: 0
    CC: 0
    pH: 8.0
    TA: 30
    CA: 80
    Pool size is 15x30
    3 feet is smallest heigh. 6 feet is tallest.
    In ground pool.
    First time pool and home owner. Previous resident used prestineblue. I am moving over to the BBB method.
    From using the pool calculator, seems I need to replace 50% of the pool water... Yikes. Am I doing something wrong? Opened the pool in July after paying a ridiculous amount for such a simple task. Sand filter as been running for 8 hours daily. I dropped several chlorine tabs since opening which may have been a mistake from reading the forum. We've had several down pours of rain and hot weather.
    I purchased bleach, baking soda and borax to keep on hand.
    Any help is greatly appreciated!!
    Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: New pool owner
    Is the CA you list calcium or CYA level? Do you have a SWG? WHY do U think U need to replace 50%? Welcome!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New pool owner
    Welcome to TFP!
    Please add your pool info to you signature so that we can better help you. More here on what to put in your sig and how to do it, Pool School - Read This BEFORE You Post Also, add your state to your location <---- so that we know what climate to help you with.
    Aug 2016
    Chester
    2
    Re: New pool owner
    Sorry, correction CA was meant to say CYA (Cyanuric Acid).
    Don't think I have a SWG.
    I think I need to replace 50% of the water based on the pool calculator. I am on a mobile so maybe it's not as accurate. Or maybe I did a noon mistake testing/using the calculator.
    I can't update my sig either as I am on a mobile.
