Results 1 to 10 of 10
Thread: New to pool and forum and testing
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    I am new to pool ownership, and to this forum. I just bought a house in SW FL with an 8,000 gallon fiberglass pool. I am learning that fiberglass here is rare, but my answer has become that I bought the house and the pool came with it.
    I have been using a Taylor K-1004, and I found that my readings, at least those I could get, were off from the local pool store's. So, this morning I pulled the trigger and ordered the TF-100 Start Up XL.
    I recently did a cobalt treatment for some staining, and I had to lower the FC to 0. I have no issues with the pool, but seem to be losing chlorine during the day as I have been keeping a very close eye on it, and I just needed to upgrade my testing options.
    That is all...for now.
    Kevin
    May 2015
    Land O Lakes, FL
    527
    Re: New to pool and forum and testing
    Welcome, once you get the kit, post a full set of numbers and hoe things are looking.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    OH goodie! Another FL person!!! SWEET!
    Here is a set of links I set up for pool owners. It is a lot of info. so take it slow. It will all make sense once you start using it.
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    I am still waiting on my TF-100 kit, so I took a sample to my local pool store. Here are those numbers:
    FC - 5
    PH - 7.4
    TA - 80
    CH - 280
    CYA - 70
    No signs of problems as of right now.
    Kevin
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Let's just hold tight and wait for your test kit and self-tested results. In the meantime, how do you plan to chlorinate your pool?
    To your comment about losing chlorine. You will lose chlorine each day, it's a consumable. The key is to replace it routinely and in the correct manner.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    Liquid chlorine. There is an inline chlorinator, but adding liquid has been what I've done in addition to the inline.
    I needed a jug of chlorine today, so I went ahead and got the numbers just to have them.
    TF-100 Testing Kit
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    While I'm awaiting my test kit, what is "BBB" on this site? I have seen many references to it, but finding no definition for it.
    TF-100 Testing Kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    It's part of the original philosophy behind the origins of the TFP method, bleach, baking soda and borax I believe. It escapes me how that acronym persists to this day. We don't use it anymore.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is some more info on that, Pool School - What is TFPC?
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    Got it. Tnx
    TF-100 Testing Kit
