Thread: Help with variable speed pump schedule please?
    Jan 2016
    Delray Beach
    52
    We just completed our new pool and filled her up on Wednesday. I have a Jandy variable speed pump and have been running it at 3450 all day and night since the fill. I think it is ready to go on a more normal schedule and speed, but as a first time pool owner, I'm pretty clueless about what speed to use for how long at what times of day. The pool is free form 15000 gallons, Tahoe blue diamond brite with a spa. I am located in South Florida. It will eventually be a salt pool but we are waiting 30 days to help the new finish. The pump is Jandy VSP 2.7hp with an iAqualink controller. Your help is so appreciated!
    -Chad
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,253
    Re: Help with variable speed pump schedule please?
    Nice pool!!!
    Here's an article that will be helpful. Pool School - Determine Pump Run Time
    You have to start somewhere, and if it were me, I would start with low speed for 8-10 hours per day, either the default low speed or something around 1500 RPM. If it's not enough for filtration and making the water sparkle, increase is a bit.
    Take a look at "read before posting" linked in my signature below. Following the advice there will help you get the best possible advice.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    213
    What an awesome backdrop! Did your pool builder set the pump to run that high? Mine did the same thing. I don't get why they recommend it as it seems like they think we have money to burn. LOL.
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
