Results 1 to 7 of 7
Thread: SWG Pump Time and Chlorine percentage
    Aug 2016
    Atlanta, Ga
    27
    Hello All
    I am coming off a slam and trying to figure out the optimal setting in terms of pump time and chlorine output percentage going forward while my chlorine decreases. Seeing that the saniclear 20 outputs a maximum chlorine of .33kg (~.7 pounds) is there a cool formula to determine what is the optimal chlorine percentage as well as pump time? If not, based on my pump information of 34-85 gpm (average ~60 gpm) I am thinking at a minimal I will need to run the pump for around 6 hours. Assuming I run the pump for 6 hours, I am but not sure exactly how to calculate the setting that would be best for me. Please help.
    Thanks!!!!
    hardness 250
    tc 15
    fc 15
    ph 7.6
    CYA 70
    17500 gal, IG fiberglass, 1.5 HP Jacuzzi pump, 350 lb Sand Filter, Saniclear 20 SWG, Aquabot Rapid XLS Automatic cleaning robot. TF-100 Testing Kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: SWG Pump Time and Chlorine percentage
    Yes, there is. Here is the member's thread who created it, it is in his sig.
    Formula for SWG / Pump Runtime?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,515
    gmike,
    Wow.. looks like the you are going to have to run your pump for 16.4 hours with the SWG at 100% just to replace 3 ppm of chlorine.
    Sounds like it is time for a bigger SWG or a variable speed pump..
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Note that you will need to know the actual "function time" of your swg. That is how many minutes the manufacturer considers to be a full cycle. Then the output will relate to a percentage of that run time. Most do not modulate, they simply switch on or off for a duration based upon the cycle time.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Aug 2016
    Atlanta, Ga
    27
    Thanks. This is exactly what I am looking for. That post should be a sticky.
    Quote Originally Posted by Jimrahbe View Post
    gmike,
    This might be a silly question, but can you mix and match the controller with the cell? For example, can I keep my Saniclear 20 controller but connect it to a Aqua Rite T-15 cell?
    May 2015
    Land O Lakes, FL
    527
    Here are the results of the calculator:
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jul 2014
    Bedford, TX
    7,515
    Quote Originally Posted by gmike09 View Post
    Sorry, but I truly doubt it. Most SWG controllers are matched to their respective cells.
