Thread: Granite plywood underlayment near grill?
    Mar 2013
    San Jose, CA
    25
    Hi all,
    Pizza oven and bar are done so now I'm working on the kitchen. It's metal stud with cement board construction. I have granite for the counter top and was planning on using plywood under it as I did with the bar. I'm concerned about the exposed edge of the plywood under the granite near the grill. Can I cover that edge with the cement board that will cover part of the interior of the enclosure or is that enough separation? Can I use cement board under the granite instead of plywood? That doesn't seem as rigid. I should point out there isn't an insulated jacket for the grill.
    thanks much,
    Steve
    14x28 Hydra Pools vinyl pool. EasyTouch, my own web interface (Screenlogic died), Intelliflow VF, 3 Pentair GloBrites, Pentair Master Temp heater, Hayward DE filter. 89" fiberglass spillover spa
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Granite plywood underlayment near grill?
    Are we talking about a slab of granite or tiles? A slab would support without plywood. You can just cut the plywood back away from the edge of the grill.
    chiefwej
    Mar 2013
    San Jose, CA
    25
    It's a slab but 2mm not 3mm. How far would you cut the plywood from the edge of the granite?
    thanks
    Steve
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    What kind of grill are you using?
    chiefwej
    Mar 2013
    San Jose, CA
    25
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You should be able to check the install manual for clearance requirements. If you are concerned about supporting the top, I have an overhang on my kitchen bar top that is braced underneath with a steel angle. The granite is glued to it with silicone. That will provide more support than plywood and is non combustable.
    chiefwej
