Thread: Pool Being Finished On Tuesday.
    So my pool has finally reached the final stages and I am in need of some advice.
    After the pool has finished filling the pool company will be adding the chemicals to get the water initially balanced. So my question is this..
    Should I let them do their thing and start dumping chemicals in and adjust after they leave, or should I nip it in the bud before they add anything to the pool that might be questionable.
    20 ft x 40 ft 33k gallon in-ground gunite pool, TF-100 kit w/ speed stir
    3 sheer rainfall decent water features
    Pentair 3hp variable speed pump
    Pentair IC60 SWG
    Pentair Quad DE 60 filter
    Jul 2015
    Central Valley CA
    1,107
    Re: Pool Being Finished On Tuesday.
    They usually will not add anything harmful and you don't want to do anything to jeopardize the warranty. For ours I let them do their thing with the exception of CYA I asked how much they intended to add. They were going to put 70ppm, i asked them to only go to 30 and I would adjust up from there if I thought there was a need they were fine with it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Quote Originally Posted by atttech-2 View Post
    Thanks for the tip. I will keep an eye on it and ask. I will bump up the cya when the swg is ready to be turned on.
    Pentair IC60 SWG
    My replaster included (well, I obviously paid for it) the first 30 days of maintenance. I would trust them to do what's required for the warranty but no reason you can't ask them what they're going to use.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
