Thread: Pool cleaner getting stuck
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    My pool cleaner keeps getting stuck by the main drain it's a MayTronics titan plus
    Is there anything I could buy or any suggestions I can do
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Re: Pool cleaner getting stuck
    Quote Originally Posted by rolo918 View Post
    Here is an earlier thread:
    Dolphin getting stuck
    This is from their troubleshooting page:
    My Dolphin gets stuck on my VGB main drain cover.
    Try turning your pool pump OFF while your Dolphin is in operation. The
    additional suction from the main drain may contribute to your Dolphin
    getting stuck.
    Depending on your model, there may be a solution to this problem
    available from Maytronics in the form of a replacement impeller cover.
    This alternate cover angles the water expelled from the impeller
    backwards rather than straight up, which can propel the Dolphin off of
    high VGB main drains.
    If no such VGB solution exists for your Dolphin model, there are a
    variety of after-market, 3rd-party devices which can be installed on or
    over your VGB drain cover to prevent your Dolphin from getting stuck.
    I have this in my pool and I don't have any issues:
    Amazon.com: Triodyne TSS-2800CS 8 Main Drain Grate with Hardware - White: Home Improvement
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
