Thread: Need help adapting Pentair Optiflo Pump to Splash SuperPak Filter
    Aug 2016
    Lomita
    1
    After 14 years, our pump started leaking. To replace from Splash Pools was $425, so I found what I thought was the same pump on Amazon for $278. The outlet to the filter housing is not in the right position, nor is it the right size. Has anybody made an adapter to fix this problem? Additionally, new pump is 1 1/2" and filter union half assembly is 2". I contacted Pentair, the maker of our original and our new pump, they said that they could not help me with my problem, but to contact Splash. I contacted Splash, they said that they could only supply an adapter for pump replacements purchased through them because Pentair manufactures an adapter exclusively for Splash. Any suggestions would be appreciated.
    Splash SuperPool, 9x17, PLM-150 SuperPak Modular Media System (Pentair Sta-rite 1.0 hp pump), purchased in May 2002, Solar heating system added in May 2004, empty during winter - but left standing, located in So Cal
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Re: Need help adapting Pentair Optiflo Pump to Splash SuperPak Filter
    A picture of your current equipment pad, showing the pump area might help us come up with an answer. Depending on how much room is available it might change the answer.
