Results 1 to 18 of 18
Thread: Pool Update - The Eagle Has Landed
    Jul 2016
    Marcellus, NY
    323
    Just wanted to give a quick update for those who had been following my ordeal in the last two threads on the subject.
    After some more cleaning, maintaining chlorine and a wee bit of DE added to the filter, we have a totally swimable pool. Huge thanks to CJ, Leebo, and kimkats for all their help! We've been enjoying the pool all this week and, you were all right, it was worth the blood, sweat and tears I put into it.
    10,400 Gal Pool, Hayward Dreamline Sand Filter Model S190TSCPE, Hayward Power-Flo LX Pump
    Jun 2015
    N Tonawanda, NY
    480
    Re: Pool Update - The Eagle Has Landed
    I was following your last thread & couldn't believe you were ready to give up. Glad to hear it's clearing up, it'll keep getting better from here.
    I suspect the filter is why it took so long to clear up. What's your pressure after backwashing & after adding the DE. Keep a close eye on your PH & FC and you shouldn't have any trouble.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Jul 2016
    Marcellus, NY
    323
    After the amount of time and effort I had invested, when it seemed to be going nowhere fast, and THEN it seemed like my filter had leaks, I was ready to call it quits. Glad I didn't!
    PSI is 16 clean and 18 with half a cup of DE. I might backwash again this weekend and do 1/4 cup just to keep that pressure up.
    Im letting my FC dip below 10 today so I can test PH, but I'm thinking it's ok.
    Jun 2015
    N Tonawanda, NY
    480
    To a certain extent a sand filter cleans better when dirty. You might want to wait until the pressure gets to 20.
    I hope you & the family are using the pool!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    Jul 2016
    Marcellus, NY
    323
    We sure are! Every evening after dinner even despite the cold snaps at night! My 2 year old is having a blast!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    ...........and we'd like to thank YOU for the donation!! Even a larger thank you for the kind words!! Im so glad all worked out for you and look forward to seeing some photos of that little one enjoying the water.
    Jul 2016
    Marcellus, NY
    323
    The donation was a no-brainer. You guys are worth every penny.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Thanks for supporting TFP! Nice pool!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    This makes my heart happy! Thanks for the support. I hope it all goes well for you from now on.
    Jul 2016
    Marcellus, NY
    323
    My only concern at this point is the two tiny holes I found in the floor of the liner and the amount of sand I've been finding in the floor. I thought I vacuumed it all up yesterday, but when I got in today there was a bunch there again.
    Maybe I missed some? Maybe it's coming in the holes in the liner? Maybe it's coming in from the filter somehow? Hard to say. I'm going to start by patching the holes and see if that keeps the sand out. Hopefully Walmart carries patch kits. If not, I'll have to get it on amazon.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    also try Home Depot and Lowes. Last resort, pool $tore.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Quote Originally Posted by Guybrush3pwood View Post
    Could be possible.. If you have sand under the liner, the leaking water could be displacing the sand... long shot but maybe..
    Keep an eye on your return after you backwash... if you have cracked lateral, the sand may shoot out right after a backwash.. If it does then its time to tear that filter a part and check the guts
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    That pool looks amazing compared to the first pictures!! Congrats on sticking with it to the end! Like CJ said, you may have cracked laterals but a little sand in the pool isn't the end of the world. I plan to take mine apart and replace the laterals next spring at opening as I get the same thing after a backwash.
    Again, great work! Enjoy the fruits of your labor!
    P.S. How's the wife liking it? I seem to recall she wanted it tore down in one of those threads somewhere!
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jul 2016
    Marcellus, NY
    323
    She's enjoying it! She admitted she was glad we kept it.
    Yeah, after some research I'm almost certain the sand is due to cracked laterals. Not a big deal, not season I was wanting to overhaul the filter anyway, so that's no big deal, but...
    ...I found at least three holes in the liner. Not large by any means, but still, and since the patching didn't go well, I'm thinking it'll have to be replaced, and since it's likely to cost $800 to 1k to have it done, this pool maybe be destined for the scrap pile after all. Something we will have to evaluate next season.
    Jun 2015
    Fairfield Twp, OH
    216
    Have you been adding a bunch of water? How did you find the holes? If you had trouble patching them, maybe find a pool guy in the area to do the patches for you. Definitely would be less than a liner.
    Jul 2016
    Marcellus, NY
    323
    I just happened to spot them. Patching just seems impossible. Not only do I have to keep track of pebble sized holes, but I have to hold my breath, try to stay down, and manage to keep the patch pressed together, open it quickly and apply it. It's quite the impossible mission.
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    Lol! Having installed a couple patches I know exactly what you're talking about!
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
