Results 1 to 8 of 8
Thread: Mobile Version
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Mobile Version
    When using the mobile version of this forum, how do you mark a forum as read?
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,084
    Re: Mobile Version
    Hmmmmmmm
    That's a good question and one I don't have an answer to. Let me look around and try to find a work-a-round.
    Jul 2011
    Eastern Ohio
    7,084
    Re: Mobile Version
    I just wanted to quickly touch up on this again. It appears there is no way for some reason to conveniently mark all posts as read in the mobile version of vBulletin. I will continue to work on this and try to setup a link somewhere in the mobile site to achieve this.
    Good Catch!
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Re: Mobile Version
    Leebo,
    Thank you so much for your consideration and time. It would just be so much more convenient to be able to mark forums.
    Thanks again!
    Jul 2011
    Eastern Ohio
    7,084
    Re: Mobile Version
    You should now see at the very bottom of the page the option to "mark forum read." This option shows up by the "full site" and "top" option. Give that a try and see if it works for you.
    Good suggestion! I never knew that option wasn't included in the mobile version.
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Re: Mobile Version
    Thanks so much! I will definitely give it a try.
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Re: Mobile Version
    I was able to try the option. I received the error message:
    Your Submission could not be processed because a security token was invalid. If this occurred unexpectedly.....
    Appears it takes a certain permission?
    Jul 2011
    Eastern Ohio
    7,084
    Re: Mobile Version
    Well crud,
    Looks like I've got more work to do as I just got the same error. I swear it worked the other day!!!!
    I'll look further into this.
