Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Super II Pump died, New SuperPump seems weak & sucking air Hayward
    fox_and_hound's Avatar
    Jun 2013
    Sunny Florida
    79
    Hi guys, so we had a big lightening surge and lots of appliances, trees, were hit in my town. My Super II 2Hp pump died. It was one speed. After the surge it would just keep humming. Thanks to the posts here, we replaced the start capacitor and were really excited that we got it to run, but it would trip the breaker quickly. It seemed to sound harsher and within about 7 seconds, the breaker would trip. I wondered if the thermal overload was shot. I could tackle it but I am hosting a bday party for my son so I had to just replace because no local store didnt have it. I still dont know if that would have fixed it. I still have it and I want to try to fix it one day LOL.
    Anyhow, all the local stores had was a terribly overpriced superpump 2Hp one speed. After the install, the pump seems not up to par. Upon closer look, the pool returns are bubbling, making noise, and I believe this is a problem with the basket and top seal. When I shut the pump off, water spits out of the top seal at me. It seems like a manufacturing issue. Im guessing this is where air is being sucked in as well. I saw someone else posted this same problem on an amazon review.
    So, what to do? Pool store says contact Hayward. Sigh.
    I also wanted to ask what are the key differences between superpump and super II pump? I feel like I made a mistake. I miss my ruggedized Super II which was quieter as well it seemed. My pool is 28k, 10ft deep, 3 returns in pool, 1 skimmer, 4 returns in spa, and 2water curtain features that sadly wont work unless the pool returns are off. It seems plumbed that way. I had a pool company come and no one understands it, they say it seems it need a separate pump and change of plumbing connections. Thats another issue altogether though.
    28k IG with Spa, hayward Super 2hp pump,
    120BTU Heater, Pentair PXC125 cartridge filter
    Love my Dogs, Maintain a Reef Tank, Foodie :)
    Jun 2013
    Sunny Florida
    79
    Re: Super II Pump died, New SuperPump seems weak & sucking air Hayward
    Hi there, anyone know if it sounds like the thermal overload might be the issue in my broken superII pump? We already replaced capacitor. Pump runs for few seconds and then trips breaker. I guess maybe motor bearings wiring could be possible? Any way to know?
    What are key differences for superpump and superIIpump 2hp?
    anyone else experience air sucking in from the top plastic of superpump? Im going to send a video to hayward
    38,521
    The super ii is a much larger head pump that moves significantly more water than the regular super pump. It is very likely that the new pump you got is too small to support the spa jets.
    Can you return it? I would suggest a new 2 speed motor on your old super ii.
    Jun 2013
    Sunny Florida
    79
    Why a 2 speed? Does that mean that sometimes during the less speed it will move less water and during the high speed, more water? Will this affect the look of the water coming out of the spa? It barely trickles out now.
    Not sure if I can return it, bought it at pinch a penny.
    38,521
    You would run high speed (equivalent to the single speed) when you need high flow like for the spa. Then usually run on low just for circulating and filtration to save money on electricity.
    Jun 2013
    Sunny Florida
    79
    is 2 hp enough or is 2.5-3hp needed? I dont really get much spillover at the spa. We have 28k gallons, 10 ft deep, 3 returns in pool, 4 returns in spa, 2 water curtain features that dont run at the same time sadly.
    38,521
    I would think the 2hp should be enough. Was your super ii enough flow for the spa?
    Low overflow is likely a valve position issue.
    Jun 2013
    Sunny Florida
    79
    I never thought the super II was enough flow for the spa. In spillover mode, it barely came out with super ii pump, but now seems worse with super pump. Maybe my valves are wrong. Ill look for a pic.
    38,521
    Sounds like your overflow valves are incorrect if the super ii was not enough. That is a very large pump
    Apr 2015
    tucson, arizona
    1,136
    Seems like the 2hp SuperII is to big a pump for your filter also. You are probably pushing that filter to it's limit all the time, then it goes through the heater and back to pool and waterfeature. Would have to see a picture of your valve setup, the only way to get more water to your water curtain would be a second pump or a bypass of the filter and heater.(Not recommended)May be same reason spa jets aren't very strong
    Apr 2015
    tucson, arizona
    1,136
    Jun 2013
    Sunny Florida
    79
    Thanks guys, Here is a pic of pool valves in pool/spill-over mode. Or so I thought,,,? Do I have the valves right?
    So what size filter is recommended?
    I can see from specs that the Super II has 130 gph and 75mm head
    Super I has 120gph and 90mm head.
    Looks like Super I might be better for me with more head??? Im so lost...
    38,521
    I see no picture.
    No super pump is typically large enough to support spa jet flow requirements.
    Forget about head calculations, they are not straightforward. Just pick a head number and compare the flow rates between pumps to see the difference.
    Jun 2013
    Sunny Florida
    79
    38,521
    Not plumbed very well. If you want more spa overflow, then you have to limit flow to the pool like the valve is actually in the picture. The only way to stop flow to spa to to turn the red handle valve.
    Jun 2013
    Sunny Florida
    79
    Ok they said they will take it back for a credit, so now I dont know what to do. I need help. What pump should I replace with??????????? Super II 2 hp or Super II 2.5 hp. I dont know what if anything I can do with plumbing. I would liek to replace pump with something that can handle spa jets.
    38,521
    What you originally had should be plenty of pump for 4 spa jets. Again I suggest the 2 speed version.
    Jun 2013
    Sunny Florida
    79
    Hey! I appreciate this so much! Are you saying that based on the head? I dont know enough about this, but do Spa jets need more head?
    The comparison between super II and super I is this:
    38,521
    The spa jets cause more head, and generally need higher flow rates to work correctly. The original pump was one of the largest, strongest pumps available. You can not go much bigger and you should not need to. If you are worried, get a 2.5 hp super ii. But it will cost more to buy and more to run. Still suggest a 2 speed. You might should just need a new 2 speed motor for your old pump.
  20. Back To Top    #20
    Apr 2015
    tucson, arizona
    1,136
    Can you post the exact model number of the Super II you had? You are reading the pump curve chart wrong. I know this is all new to you, but a full rated 2HP Super II should have been more than enough to run everything. More than likely you need advice on the way to use the valves to optimize your flow. Any other pictures of the equipment from different angles could help.
