Thread: Lamotte Waterlink Spin Lab Vs Taylor Drop Test
    Aug 2016
    Boston
    1
    Hello,
    I brought my spa water for testing at two separate places with the following test results:
    1st place (using taylor testing chemical drops)
    free available chlorine: 5
    total available chlorine: 7.5
    calcium hardness: 50
    cyanuric acid: 0
    total alkalinity: 100
    ph: 7.4
    2nd place (using LaMotte WaterLink SPIN Lab)
    free available chlorine: 3.32
    total chlorine: 21.33
    calcium hardness: 0
    cyanuric acid: 15
    total alkalinity: 76
    ph: 7.3
    With these results, I'm baffled as to why the test results are so drastically different in regards to the total available chlorine. The first place testing at 7.5 ppm compared to the 2nd place testing at 21.33 ppm????? Has anyone ever received similar test results for the total available that appear to be this drastic in comparison? One place is obviously totally off here and I'm not sure who's test to believe. Although, I've read a number of postings that the Taylor drop testing is more accurate. Therefore, any thoughts would be appreciated.
    Regards,
    Matt
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Lamotte Waterlink Spin Lab Vs Taylor Drop Test
    Welcome to TFP!
    They are so vastly different because we find that most pool stores are horrendous at water testing. We don't recomend anyone go there to have water tested. We recomend you get your own quality/accurate test kit and use it for your own testing.
    Also note, that yes, Taylor drop testing is better testing in our opinion, but only if done correctly. Most pool stores don't get it right, even when using Taylor tests.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Thanks for showing yet again that pool store testing is unreliable and that we are correct to recommend that people test their own water at home with a good test kit like the TF-100 from TFTestkits.net.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    This post should be required reading for every new user that comes on here with a set of pool store results.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Nov 2015
    VT
    85
    I wish you (OP) could have also supplied your own results.
    Please repeat after you get your own test kit.
    I have screwed up with a test kit. I might anticipate how many drops it will take before changing the color so I "cheat" and add more than one drop at a time. Then I blow right by the indicator and have to start over.
    The guy at the store might do the same but not bother to start over. He just gives you a number.
    Hot Springs Sovereign (1999?)
    May 2015
    Quebec, QC
    37
    It would be interesting to obtain 'same operator' statistics on the Lamotte Spinlab. The cell filling phase requires a repetitive light touch to prevent over or underfilling. The printed computerized suggested 'corrective measures' are usually overkill; trying to correct every little deviation on every single measured variable. Some AI is clearly missing here.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
