Results 1 to 14 of 14
Thread: Pool 911: Fungicide/Insecticide added to pool water...HELP
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    Water added to my pool today had Fungicide/insecticide in it. There was an oily sheen on the surface of the water and the water smelled like chemicals. My skin is burning just from doing a water test. The pool is getting drained right now and will be empty by morning. I will need to clean every bit of that oily residue off before refill tomorrow morning. What do I use to clean the pool surfaces and remove the oil?
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Pool 911: Fungicide/Insecticide added to pool water...HELP
    I would stop draining, refill and slam the pool. Chlorine will break it down.
    Aug 2014
    Northern IL
    4,615
    Just curious. How do you know there was fungicide/insectide added?
    S1ngram's Avatar
    Jun 2014
    304
    I have had chemicals in my pool before, nothing this bad, but I spent an entire summer trying to feed my pool enough chlorine to get rid of the chemicals. My husband was willing to do a drain and refill so I wouldn't have to go through the mess I went through before. The pool is already empty except for about 3". The plan is to have it filled again before lunch tomorrow. I just want to make sure it is safe. If the chlorine will break down the chemicals, I'll just use dry towels to wipe away the oil I can see.
    My husband it a farmer. We own the tanker that was used to fill the pool. There was a miscommunication and the person filling the pool used the wrong hose (a hose that had been used to fill crop dusters with Fungicide and insecticide).
    DFW, TX
    24,514
    A little dish soap and bleach in a spray bottle will help the wipe down.
    Aug 2014
    Northern IL
    4,615
    Best wishes!
    S1ngram's Avatar
    Jun 2014
    304
    Thanks everyone, I'll be using pooldv's spray cleaner idea and wiping down the walls, steps and everything else with some old towels. My husband wants to drain completely just to be on the safe side. The insecticide he is concerned about is field applied at 6oz. per acre. Even though it was added in a diluted form, we don't want to take chances since we don't really know exactly how much went in the pool. I will send updates. I never thought anything like this would happen.
    Aug 2014
    Northern IL
    4,615
    Aww. Stuff happens.
    DFW, TX
    24,514
    That is pretty strong stuff!
    S1ngram's Avatar
    Jun 2014
    304
    Liner now has an 8" tear in the bottom. If anything can go wrong it will. Off to pool store to see if it can be patched.
    S1ngram's Avatar
    Jun 2014
    304
    Liner is patched, water going in. Wish me luck
    Aug 2014
    Northern IL
    4,615
    Good luck!!!!
    S1ngram's Avatar
    Jun 2014
    304
    The patch held overnight, so that's a good sign. My face and arms are feeling back to normal. And really, I have all the moderators and other folks here at this site to say THANK YOU to! So, thank you, for my swimming pool knowledge. Several summers ago when I started my pool, all the people here at this site worked with me to help me get my pool in order. It's because of all of you that I pulled through this most recent situation without having a panic attack or relying on a pool store for advice. Fortunately, here in the Midwest water is cheap and patches are pretty reasonable, even at a pool store.
    THANK YOU!!!
    DFW, TX
    24,514
    Alright! Good news!
    Want a nifty badge? And some other fringe benefits?
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
