Thread: Taylor K-2006 unboxing
    Aug 2016
    Montreal, Quebec, Canada
    27
    Hello
    I recently bought a spa with SWCG. Having trouble with managing pH, and following suggestions on this site, I decided to invest in a Taylor K-2006 test kit.
    Here is an unboxing video of the kit.
    Here is a link for the Taylor K-2006 test kit from amazon.com.
    After recording the video, I did run tests, and successfully managed to bring my TA down from 120 to a target 50, and the pH from 8.1 to 7.5 in a matter of a few minutes. I am glad I purchased the kit and look forward to continue using it.
    Any comments welcome.
    Cheers!
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Taylor K-2006 unboxing
    Welcome to TFP
    Sounds like you're off to a great start
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Aug 2016
    27
    Thank-you AimeeH.
    Apologies for omitting to mention the booklet also included in the K-2006 kit. It contains very helpful explanations on water chemistry, along with several tables to help calculate quantities based on current values, target values, and pool size.
