Thread: Spider gasket question for Hayward SP0710X62fV
    Apr 2011
    The Bluegrass State
    61
    Anyone know if this particular valve requires the entire top half of the valve to be replaced or can I just replace the gasket? Does replacement require glue? Lube? Appreciate it, as always!
    All I know about my pool at this point:
    Size: 17,000 Gallons - Oval
    Type: Inground - Vinyl - Salt Water
    Filter: Sand
    Controller: Autopilot
    Pump: 1HP Waterway Mustang - Single Speed (MUSTS-110)
    Heater: Aquacal Heat Wave
    Robot: Barracuda G4
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    Re: Spider gasket question for Hayward SP0710X62fV
    Here's a bump
    You might find this helpful: How to Replace a Spider Gasket on a Multiport Valve - INYOPools.com
    I don't know anything special about your MPV, but I haven't heard of a need to replace it unless it's broken.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
