Results 1 to 8 of 8
Thread: Shock or Mustard Algae Shock?
    Jun 2016
    Acworth, GA
    44
    Pool has been great all summer using the TFP process. Last week we started getting brown/yellowish algae so we shocked for 3 days and passed the OCLT.
    Yesterday, my sister saw a yellow spot and the pool was a little cloudy so we went ahead and shocked again thinking the algae had come back.
    So, my question is, should I be doing a regular shock or mustard algae shock? We used to get mustard algae every August so it's no surprise if it's that.
    see attached.
    ~33000 gallon, IG, vinyl pool, 3 1/2 foot shallow with ~10 foot diving well built ~1985. Old Hayward side mount sand filter, with new Hayward Multiport SPX0710X32 replaced 5/2016. Pump and Motor replaced 5/2016 with Pentair WhisperFlo 3/4 HP Fluid End pump (WFE-3 part# 075452 Inyopools) and Century Centurion 3/4 HP motor, B2847. Leslie's simple test kit / taking sample to Leslie's, New Dolphin pool cleaner, No well, No Water restrictions
    Jan 2012
    'burbs of Augusta, Georgia
    7,365
    Re: Shock or Mustard Algae Shock?
    Uhmmm....well...we don't "shock" pools here at TFP. When necessary we do a process we call a SLAM. That means "Shock Level and Maintain". Its not a one time dose of anything. SLAM
    If you have algae problems you've got chemistry problems.
    Please get one of our recommended test kits and give us the most current:
    FC
    CC
    pH
    TA
    CH
    CYA
    THanks
    Yip
    30,431
    +1 what YS says.
    Jun 2016
    Acworth, GA
    44
    Quote Originally Posted by YippeeSkippy View Post
    FC
    CC
    pH
    TA
    CH
    CYA
    THanks
    Yip
    Yeah, SLAM, but the calculator does say 'Shock'. I slammed it last week, started again last night. Need to know the difference and when to use which one between TFP calculator 'shock' level and mustard algae 'shock' level when slamming.
    TF-100 test kit
    FC 27
    CC. 0
    pH. 7.5 before slamming
    TA. 110
    CH. Vinyl
    CYA. 60
    Based off my CYA I've been keeping the FC between 7 and 10
    Jan 2012
    7,365
    Hmmmm...that's a dilemma why you would have problems so quickly after a SLAM.
    Have you been brushing the pool, both to insure good circulation of your chlorine to all points but also to disrupt any possible algae biofilm present? Does this algae appear in a particular area such as a shady spot?
    When you did your SLAM, on that last day did you take your FC up to the mustard algae level for 24 hours before ending that SLAM? Did you wash off any toys that go in the pool to rid them off any algae?
    Do you have a light niche that needs to be cleaned out behind- that's a common spot for algae to hide in.
    triptyx's Avatar
    Apr 2016
    1,438
    Skippy touched on an important point - the Mustard SLAM level is only for a 24 hour period. You don't want to maintain that higher level for the entire SLAM.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Acworth, GA
    44
    Quote Originally Posted by triptyx View Post
    Yep, I did everything but the last 24 hour period, so maybe that was my issue. Thanks
    triptyx's Avatar
    Apr 2016
    1,438
    Make sure you've also cleaned out any sources of algae. Underneath ladders, behind light fixtures, etc. If you think you got it all and you missed a "nest" of algae hiding inside/under/inside something, you're going to be SLAMing over and over until you find it and clean it out!
