Thread: Vinyl lined pool stairs
    May 2014
    Dfw
    29
    Hi there. Just needing some help on my options for refinishing the stairs on my vinyl lined pool. The stairs are white fiberglass and they are looking pretty tired. Is there a product out there? Ideally i would like to drain it down so they are dry and fill it back up soon after. What kind of paint works on these?
    14k gallon, vinyl in ground, 1 hp pentaire pump, pentaire sand filter, taylor k2006 kit,hayward shark vac cleaner, pool blaster cg vacuum
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Vinyl lined pool stairs
    I believe that it is better to use a gelcoat product on fiberglass, not paint.
    May 2014
    Dfw
    29
    Can anyone recommend a product or have any experience with refinishing fiberglass stairs I can't find much on a suitable kit out there. Also is it safe to drain the pool (just enough to expose the stairs) or will the liner shrink? I remember seeing something years ago about having to always leave at least a certain amount in the shallow end but I can't find it now
    Mar 2016
    Hurricane , WV
    7
    I refinished mine with a kit from poolstepspecialits , they shipped it from Canada. It is some sort of epoxy gel coat , a little pricey but did the job . I did it one year ago and so far so good .
    DFW, TX
    24,450
    It is best to leave a foot of water in the shallow end when draining a vinyl pool to prevent liner shift, shrink, etc.
    Mar 2016
    Hurricane , WV
    7
    I did mine when the liner was being replaced so the pool was empty .
