Thread: CYA ????
    Jul 2015
    Chesterfield, VA
    3
    CYA ????
    Small, 3,500 gal Intex above ground pool. CYA is 88ppm and pool store told me to drain and refill. Hubby says it's not necessary to do that and it won't hurt us. I shocked the pool in the early am before the sun got bright then took a sample in to have it checked. Pool store clerk says it's to out of balance to test until the shock gets to work but that at 88 ppm I need to drain some water and refill.
    We changed out the cartridge filter to a Hayward sand filter this season.
    3500 gal, AG, Cartridge filter type A, Intex Easy Set pool w/filter set up 3 wks ago, well water, Ubsta-Test 5 Plus strips.
    jwhop3's Avatar
    Jun 2014
    Rocky Mount/Virginia
    78
    Re: CYA ????
    Think of cya as a chlorine retarder. It binds a certain amount to use later, so even though your test results might say your FC is adequate, or even high, you can still have an algea bloom. I have always kept mine at 50 ppm, once this summer mine got to ~70ppm, and I started chasing cloudy and green-tinged water. To know what you would need to drain, divide what you want by what you have, then subtract from 100. To get to 50ppm, 50/88 = 57% - 100 = 43%. That would be a significant drain, so it would be cheaper for you to just refer to the CYA/Cholrine demand chart and put in the required level for your cya reading.
    14,000 gallon Fox Lagoon, ingound vinyl
    PacFab Sand filter
    installed April, 2002
    Frog inline chlorinator
    Town water
    30,432
    Re: CYA ????
    Probably not much swim time left for you. I would just refer to the chart as above.
    Next year keep your FC around 50 ppm.
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    49
    Re: CYA ????
    I think he meant CYA around 50
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    30,432
    Re: CYA ????
    Sorry! Yes, CYA at 50.
