Results 1 to 7 of 7
Thread: LEAK! Inground pool. Where to begin?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    I've got a leak, inground 17K pool. Not visible in any of the above ground piping. I'm in central Florida, so the daily showers do a great job of masking it. Salt and CYA levels are going down quicker than normal splash out. With all the rain we've had the level is comes up, but I haven't had to drain out any water.
    At what point do I need to take action? I'm thinking waiting till the dry season/end of swim season. Let the pool drain down itself, to isolate it to the returns skimmer or else where.
    I'm hoping it not a crack caused by a root from the tree.
    Any suggestions/recommendations? I'm all ears.
    Thanks in advance.
    Bob
    Jul 2015
    San Marcos, CA
    110
    Re: LEAK! Inground pool. Where to begin?
    Are you sure you have a leak? Have you done the bucket test?
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    Apr 2011
    Murrieta, CA
    2,360
    Yes, I have a leak. CYA and Salt do not evaporate.
    30,432
    The wide variance of the CYA and salt test would probably not be a good indicator.
    It's gonna' dry out pretty soon. Let the pool evaporate down until it stops, that should locate the leak for you.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Your on it, it should stop dropping once it is below the leak..
    Apr 2011
    Murrieta, CA
    2,360
    Yeah. That's what I was thinking, I'll update as I learn more.
    Apr 2011
    Murrieta, CA
    2,360
    This is frustrating. With all the rain didn't need to drain, but not it's not draining any more. Go figure. Waiting for the dry season.
