Results 1 to 14 of 14
Thread: First time pool owner - first next steps
    Aug 2016
    San Antonio
    8
    Howdy. First post warning. I've read lots of posts, many of which are still Greek to me. And now I'd love to have some expert advice. I shocked the pool with the last of my old bag shock (cal hypo) about 2 weeks ago. A few days later, it started getting cloudy and is turning green now.
    I was unsure of my test kit results so I had a water sample tested at Leslie's pools this Am. Here are my current standings.
    FAC 10
    TAC 10
    CH. 250
    CYA 200
    TA 120
    pH 7.8
    Tot diss solid 450
    phosph. 300
    photo of green pool is attached.
    Next steps? Partial Drain and refill to lower CYA to get chlorine working?
    Jul 2015
    San Marcos, CA
    110
    Re: First time pool owner - first next steps
    Welcome aboard!
    First, don't trust Pool $tore readings. Use the appropriate kit and test yourself.
    If your CYA is that high, then you do need to drain the pool. Here is a link showing the CYA level you want. But wait until you have your test kit and can confirm the CYA is that high.
    Post your levels when you get your kit.
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    May 2012
    Toronto, ON
    463
    Your pool looks like it is ready to host the Olympics diving competition - congratulations!
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Aug 2015
    Grandy, NC
    135
    DO NOT USE ANY POOL STORE CHEMICALS. We need additional info such as pool size, what kind of pump, filter, other add-ons. We call this adding a "signature" to your post. Until you have a good test kit, it's hard to guess what may be going on. SLAM is based on adding chlorine bleach according to your CYA (stabilizer). Since we can't trust pool store analysis, hard to guess numbers.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Aug 2016
    San Antonio
    8
    Not sure why my signature didn't show up on the first post. I filled it out earlier. I'll get a test kit and check cya, I suppose.
    25000 gal, plaster, pool pump pentair challenger CHII-N1-1 / centurion motor 1.5 HP; sand filter Purex triton tagulus TA-50/50d; Polaris PB4-60 booster pump; on city water.
    22000 gal, plaster, pool pump pentair challenger CHII-N1-1 / centurion motor 1.5 HP; sand filter Purex triton tagulus TA-50/50d; Polaris PB4-60 booster pump; on city water.
    Jul 2015
    San Marcos, CA
    110
    Remember, all test kits are not created equal. You can't get the recommended kit at Walmart, for instance. I know you can get the Taylor K-2006 at Amazon.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Quote Originally Posted by wayner View Post
    Ouch! But funny.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Aug 2016
    San Antonio
    8
    Ok. Taylor k2006 test kit received. Here is what I got as results.
    3.5 ppm free chlorine
    0-.5 (?) ppm combined chlorine
    8+ ph (5 drops acid demand)
    16 ppm total alkalinity
    38-40 ppm calcium hardness
    Cya well over 100, off the charts, likely 160+ based on scale
    Pool is now a full on nasty green. Have had lots of rain in past week also.
    Suggested next steps?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Sorry, but you're going to need to drain and refill about 80% of your water to get that CYA down before you can do much else.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2016
    San Antonio
    8
    I'm going to do a partial drain. And then I'm going to change the sand in the filter after i SLAM the pool.
    Or should I change the sand prior to slamming?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Replacing sand is seldom necessary. New sand is already millions of years old. It doesn't wear out.
    Sometimes deep cleaning is necessary, but green water isn't a symptom of a filtration problem, it's a chemical problem due to insufficient chlorine relative to your CYA level.
    Concentrate on getting the algae killed first by dropping your CYA and raising your FC. Then after that, if the water remains blue but cloudy, we can deal with the filtration.
    Surprisingly, slightly dirty sand filters better than clean sand. That's why many of us add D.E. to our sand filters, ie. to "clog" them up a little bit.
    Is this a new or old pool?
    Pentair IC40 SWG
    Aug 2016
    San Antonio
    8
    Old pool. I'll do a partial drain and refill this week. Then slam. Will report back with results. Thanks for your help.
    Aug 2016
    San Antonio
    8
    Late late reply. I got the pool looking great after a 3/4 drain and refill to get the CYA levels down. Liquid bleach from there and we had a great summer this past year. Thanks for your help, all.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,412
    That is an awesome update! So glad to hear the drain and refill along with testing helped!
    Kim
