Thread: TA Insanely High
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    TA Insanely High
    I checked out how to lower TA in pool school, but I'm not sure how much MA to add and how often.
    I have been struggling with this Indiana weather all summer and if I can't get this pool under control in the next week, I am closing it down for the season. I am so tired of dealing with it. It has been a nonstop green -blue - green - blue all summer.
    Just this weekend my filter failed (or something) and everything I was vacuuming off the bottom came back into the pool via the returns. SO angry!
    Anywho, anyone have more detail to lowering TA?
    Morning Reading: 330
    PH: High (DARK PINK)
    Chlorine: ? - Didn't have time to run a full panel before work.
    Obviously the issue here is lowering the TA so that everything else will fall into place.
    TIA!
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Jun 2014
    15,298
    Re: TA Insanely High
    You'll want to use some muriatic acid and follow the instructions on the Pool School - Lower Total Alkalinity page.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Use Pool Math - http://www.troublefreepool.com/calc.html to figure out how much MA to add. Add it in front of the return with the pump on. Let it do its work. When the pH is down to 7.2 aerate your pool to bring pH back up to 7.8-8.0 and repeat. My fill water is very high TA. I am now down to 90 and watching my pH to see how it holds.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Jul 2015
    Tempe, AZ
    194
    As high as your TA is right now, your pH will rise fast enough that you'll be able to give this pool more than one acid dose per day. I'd bet that if you're aerating, the pH would rise from 7.0 to 7.6 in a couple hours.
    Keep at the process they described above and it will come down.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
