Results 1 to 9 of 9
Thread: Need LIGHTS recommendation during replaster
    Sep 2008
    The Woodlands, Texas, USA
    243
    I am having my pool replastered and 2 new lighting niches placed for pool and spa.
    What lights do you guys recommend since I can install anything at this point?
    LED would be nice, but need a brand/model with a long term low cost of ownership. This means I forget about it for the next 10 years.
    I have a GoldLine controller and saltwater.
    Lee
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Need LIGHTS recommendation during replaster
    Those new savi led lights are really kewl
    Apr 2013
    Sacramento, CA
    2,769
    The Savi Lights are nicheless. They also had issues pre Jandy.
    I would look at the Hayward LEDs. ColorLogic 4.0 Pool Spa Lights | Lighting | In Ground Pool Lighting - Hayward Pool Products
    Jul 2013
    Fletcher, OK
    3,353
    Gwegan,
    You just busted my bubble I thought those lights were doing good
    Apr 2013
    Sacramento, CA
    2,769
    I'm not sure your bubble is burst. The Savi lights had issues prior to Jandy's purchase of Savi. But I have not seen any real issues since then. They have clearly changed the lights, at least the look and I suspect more.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Ditto Gwegan. Hayward's ColorLogic 4.0 are what I'd recommend. They make a pool size and a spa size.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2015
    chino hills, ca
    1
    Avoid Pentair LED's. One of two failed at start up. Reviews are bad online such as Amazon.
    Sep 2008
    243
    I would prefer some LED lights, but bad reviews are everywhere for all brands of LED from what I see.
    Anyone have good reviews of the Hayward?
    Anyone have Hayward Colorlogic older than 7 years?
    Lee
    Jan 2015
    Spring Hill, FL
    8
    I just installed a Hayward 500 watt Universal ColorLogic White LED. I can't speak to lifetime, but it puts out great light and seemed well built. Why do they call a White LED Color Logic? Seems illogical to me.
    14x28 in-ground plaster, ~ 15000 gal, Hayward C9002 cartridge filter, 1 HP Flotec pump, Heat Siphon heat pump. 12 Mil blue solar cover, liquid chlorine.
