Thread: Need help- newbie with the FAS-DPD test
    Jul 2016
    Milwaukee, WI
    14
    I just got my Taylor 2006 test in yesterday. I've done as much reading as I can on here and in Pool School. New pool owner. Installed last Sat. Water was filled with 2.5 loads from a water delivery truck and about 8 hrs worth of water from our well, that has the faucet connected to an iron filter.
    So this was the results this morning:
    FC: 28 ppm
    CC: 0 ppm
    PH: 8.0
    TA: 330
    CH: 380
    CYA: no reading
    For my questions:
    1. From what I've read on here, it's ok to get 0 for CYA if I am doing the sock method, as it doesn't register until about a week, correct? I checked the sock this morning (it's been in for 2 days) and there's still a lot of granules in there (it's a tall sock). I've been squeezing with my hand about once per day.
    2. For CH, I read that should be under 300? How do I decrease it, or will that come down with time since it was just filled last week?
    3. For TA, if I understand correctly, if I get my PH in line, the TA will go down, correct?
    4. How do I translate the 28 ppm for FC into a single digit #? I've read it should be between 3 and 5...Or is that telling me my FC is very high? I put in 2 gal of liquid chlorine this morning as the FC was reading 0.
    EDITED:
    I did my FC wrong. The correct reading is 11 ppm. And I used 10% liquid chlorine.
    19,000 gallons AG (18x40)
    Hayward Voyager system w/ 1.5hp Matrix pump
    Install: 8/2016
    Hayward 200,000 Btu NG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Need help- newbie with the FAS-DPD test
    28 FC is way high, how many gallons of bleach did you add? Did you count 56 drops? it will come down about 3 to 5 FC per day
    the only way to reduce CH is to drain and add new water so your kind of stuck with 380, just keep your PH below 7.8 and your CSI in the 0 range
    with a TA of 330 your PH will rise very fast, You really need to drop it, here are the directions Pool School - Lower Total Alkalinity
    I hope this helps
    Jul 2016
    Milwaukee, WI
    14
    Maybe I did something wrong with the FC test...I wasn't sure what to choose when it says to use 25 mL or 10 mL...What water level am I supposed to use? I did 10 mL...
    Install: 8/2016
    domct203's Avatar
    Jun 2015
    CT
    3,592
    If using the 10ml sample, each drop is 0.5ppm. It would take 56 drops for a reading FC of 28ppm using a 10ml sample.
    2 gallons of 12.5% liquid chlorine will only add 13ppm of FC to your 19K gallon pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2016
    Milwaukee, WI
    14
    I just redid it...I misunderstood one of the steps (I didn't multiply by the ppm #). It's 11 ppm.
    Install: 8/2016
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Quote Originally Posted by rach924 View Post
    FC: 28 ppm
    CC: 0 ppm
    PH: 8.0
    TA: 330
    CH: 380
    CYA: no reading
    For my questions:
    1. From what I've read on here, it's ok to get 0 for CYA if I am doing the sock method, as it doesn't register until about a week, correct? I checked the sock this morning (it's been in for 2 days) and there's still a lot of granules in there (it's a tall sock). I've been squeezing with my hand about once per day. CYA generally takes about 48 hours to fully register. You can "help" it along by squeezing more often
    2. For CH, I read that should be under 300? How do I decrease it, or will that come down with time since it was just filled last week? Knowing your fill water levels is a big factor on this one.. If its at 380 when you fill, then you are pretty much stuck with it unless you can find a water source with lower levels... Luckily Vinyl pools don't increase over time like plaster pools do.
    3. For TA, if I understand correctly, if I get my PH in line, the TA will go down, correct? Lowering TA is a painfully slow process... Lowering PH with MA will gradually lower Ta but only a little bit at a time.
    4. How do I translate the 28 ppm for FC into a single digit #? I've read it should be between 3 and 5...Or is that telling me my FC is very high? I put in 2 gal of liquid chlorine this morning as the FC was reading 0.looks like you figured this one out!!
    EDITED:
    See above edits for some answers
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
