Thread: What order to do things
    Aug 2016
    Knoxville, TN
    2
    I'm a brand new pool owner, and over the last month I tried to clear up cloudy green water using test strips. I wasted a lot of product on wildly fluctuating readings.
    I now have a Taylor K-2006 test kit, have drained and refilled my pool, and want to adjust it correctly.
    I want to know what order to adjust readings and how slowly to go.
    My water is slightly cloudy blue.
    Today's test:
    TA 220
    pH 8
    CH 150
    No chlorine.
    I didn't test for stabilizer, but I haven't added any.
    Thanks!
    6000 gallon AG 16'x48" Summer Escapes
    Modified with Intex 2500 GPH Filter Pump
    Filled with well water
    30,413
    Re: What order to do things
    Lower your pH to around 7.5.
    Immediately after that, add enough stabilizer to get to 40 ppm.
    Immediately after that add chlorine to get to 8 ppm
    Keep chlorine at 8 ppm for 48 hours.
    If pool is still cloudy, SLAM the pool.
    Adjust the chemistry one after the other but not simultaneously.
    Aug 2016
    Knoxville, TN
    2
    Thank you!
    Once I add the muriatic acid amount from the PoolMath calculator, how long should I wait before testing again?
    Jun 2014
    15,056
    Hello and welcome to TFP! If you have any questions about Dave's instructions please let us know. FYI - since you have the K-2006 test kit, you can test FC using the 10 ML water sample size. Just test FC as follows:
    10ml sample with one heaping scoop of powder. Add drops until Barbie pink goes to clear. Multiply drop count by 0.5 (divide by 2)
    Example: 10 drops = FC of 5.
    Nice to have you with us.
