Thread: Amount of bleach needed
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    So I am at the point where I know how much I have to add before even measuring. Considering it's been hot here in upstate NY and I have a decent sized pool, is it normal to have to add a bottle of bleach a day? I feel like I am spending $3 a day on chemicals lol.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Jul 2015
    Central Valley CA
    1,109
    Re: Amount of bleach needed
    you are running 4ppm per day that is a little on the high side but not unheard of epically if the pool gets lots of sun. What is your CYA level? If it's in the 30-40 range you can try increasing it to 50-60 range and it may cut your bleach usage down a bit.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    How much are you swimming? That along with checking the CYA level may show why you are using so much bleach.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    Liverpool NY
    121
    My CYA is 60 ppm. I get full sun all day and water is between 86-88 degrees. I also use a solar cover at night. I uncover that during the day so I can clean the pool from leaves and debris and swim if I want to. I like to keep my chlorine at 8 ppm but it sometimes drops to 5 ppm. I have no CC and my OCLT is always good. I assume the sun is just blasting the chlorine.
