Results 1 to 10 of 10
Thread: Need Help ASAP!!!!
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Need Help ASAP!!!!
    We had someone turn on our pumps today....a pipe broke lose from one of the pumps and is shooting water out while draining the pool. How do we stop this?
    18 x 38 gunite, 39-7 deep, 8 x 12 tanning ledge with 8 deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16 long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    Jun 2016
    Central Valley, CA
    31
    Re: Need Help ASAP!!!!
    Looks like a threaded connection.
    Turn the pump off. If threaded re tighten. If glued then you need to dry and re-bond the PVC.
    16' x 32' IG 20k Gallon
    Traditional White Plaster
    Hayward Tristar VS Pump
    Hayward Navigator Pro
    Pentair 60 Sq. Ft.
    Aug 2014
    Northern IL
    4,615
    Turn the pump off right away. Then in the daylight you can get those guys to repair their work!
    JoyfulNoise's Avatar
    May 2015
    13,199
    Open the panel, and cut all the breakers.
    Matt
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Thank you all! We cut the breakers off and it worked. We thought the noise we heard was the rain. Thank goodness my husband checked before bed.
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Sheree, you and your family are going to have quite the tale to tell one day.. "Remember when our pool was being built...." LOL
    Good Luck!
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    What I want to know is how your picture is so clear??? I KNOW your hands were shaking and heart beating out of your chest when you saw this!!!!!!!!!!!!
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    That is actually a bonus water feature called "The Party Fountain". I hear kids and dogs love them. We thought about installing one but opted for a simple bubbler.
    In all seriousness, glad your husband checked and you got it shut down. It must have mudded the yard pretty good up as well. Keep repeating to yourself, nothing good ever comes easy...
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Quote Originally Posted by bdrex28 View Post
    Good Luck!
    Right, Brian!! I did chuckle about it today....we sat in the living room thinking that it was raining for almost an hour while right outside the window our pool water was being shot 12 feet into the air (in our defense it was suppose to storm). It's a shame we didn't realize what was happening before the water drained down to the top of the light niche. And we thought the water bill would be expensive before!!!!!
    Quote Originally Posted by kimkats View Post
    YES!! The second I saw it I was like OMG I need to get this posted on TFP.
    Quote Originally Posted by platipus View Post
    plat.
    at opting for the simple bubbler!!!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Im sorry about your water loss, and also sorry because I couldnt help but laugh a bit when I saw the pic. The good news is it's an easy fix.
    Divin Dave,
