Results 1 to 7 of 7
Thread: 2nd Pool... 1st time attempting to maintain it....we'll see how long that lasts :P
    Aug 2016
    Laveen, AZ (PHX Area)
    4
    Name is Dan and we are in Phoenix... just finished building our new pool. We had one before, but I never maintained it (had a pool guy) I'm going to attempt to maintain this one and my buddy Andrew said to check out this forum. I'm pretty familiar with water chemistry and algae control from maintaining my reef fish tanks (currently dry). I think I can pick up on this, but my main concern is time... During my busy season (spring through fall) I'm working very long hours and weekends with very little time off, so I'm hoping this can be less time consuming than I am thinking it could be (one of the reasons i'm not maintaining a reef right now). Anyways... this is my intro... so here's my new pool and putting green.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: 2nd Pool... 1st time attempting to maintain it....we'll see how long that lasts :
    Hey there! Welcome to TFP
    Tell us a little about your pool and equipment. How are you sanitizing and testing your water?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Or you can add your pool info to your sig as shown here, Pool School - Read This BEFORE You Post
    Aug 2016
    4
    It was just filled on Saturday of last week, so I haven't developed a regimen yet. I have a start up kit from the pool builder that has liquid chlorine/shock, muriatic Acid, a small tub of chlorine tabs (I bought a big tub) and some test strips. The pool is 80ft perimeter, 358 surface area 10740 Gallons, pebble sheen interior, Eco-Smart in floor cleaning system, deckclor system, ozonator, Hayward 330' Cartridge filter, Hayward 1.8HP VSP.
    Aug 2016
    4
    I saved my sig... it's not showing up yet for some reason.
    Nevermind... there it is
    Dolphin Pools, 80ft perimeter, 358 surface area 10740 Gallons, pebble sheen interior, Eco-Smart in floor cleaning system, deckclor system, ozonator, Hayward 330' Cartridge filter, Hayward 1.8HP Variable Speed, Hayward AquaConnect Automation, travertine deck and coping, putting green. Completion/Fill Date 08/06/2016.
    Jan 2012
    7,264
    Okie doke... well.. your best friend for pool care is a proper test kit. "Guess Stips" aren't very useful and can be downright inaccurate. We only recommend two- the TF-100 or the Taylor K-2006, both avail from TFTestkits.net or from Amazon. The proper testing will save you time and money and help you only put in your water that which it needs and nothing else. You also need precise numbers for the following test elements:
    FC
    CC
    pH
    TA
    CH
    CYA
    Your pool being new is going to require close monitoring of the pH, CH, TA for a few months as the plaster cures.
    You shouldn't count on the ozone system to contribute much considering you still have to use chlorine in the pool. Ozone systems are more suited for indoor pools.
    Good Read --> Pool School - Start-up New Plaster
    DFW, TX
    24,450
    Here is the general Pebble Tec care guide
    Pool Care Instructions Pebble Tec
    Go here and register your warranty and they will send you a start up guide and a tech support contact
    Product Registration Pebble Tec
    I prefer the TF-100 from TFTestkits.net, here's why, Pool School - Test Kits Compared
