Thread: Dichlor shock..how much?
    Aug 2016
    Tiffin, ohio
    1
    We just had our pool installed over the weekend, with no instructions on how to start up! We have the frog system. They said to add the shock...dichlor shock. I have no idea how much i am to add?? Ag pool hold approximately 19000 gallons. Cya is 0 free chlorine is 0. Any help is appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Dichlor shock..how much?
    Raise fc to 3 ppm. Use PoolMath, link above, to calculate how much to add. Without CYA/stabilizer in the pool you'll have to add that a couple times a day.
    Do some reading in Pool School. Start here,
    ABCs of Pool Water Chemistry
    Pool School - Getting Started
    Add your pool info to your sig so that we can better help you. More here on what to add and how to do it, Pool School - Read This BEFORE You Post
    Jan 2012
    'burbs of Augusta, Georgia
    7,243
    Welcome Newpooler
    Just an FYI- those Frog systems add metals to your water which can cause stains and green hair/nails. You might want to consider removing that element since and stick with just liquid chlorine for your sanitizer.
