Thread: Countertop construction
    Livermore, CA
    32
    Hey all,
    I'm planning my countertop right now. It will be a skim-coat concrete countertop (using ardex feather-finish), and the test sample I made looked great. What I'm wondering is the makeup of the countertop, as there will be 2 weber kettles suspended from it (a 22.5 pizza kettle and the 26 for everything else). My sample used 2 layers of 5/8 plywood (roughly, danged metric...) and a layer of concrete backer board, and it was heavy and solid enough to dance on.
    My concern is obviously around the kettles - I will be attaching a ring of steel (wine barrel hoops actually) in the countertop holes, and dropping the kettles on the rings. I'm wondering if plywood is the wrong way to go for heat/burning reasons, or will the steel ring be enough to shield it?
    I've considered 2 options - 1 is making the plywood cutouts 1/2-3/4 of an inch wider than the hardibacker and concrete will be to have some air gap, the other is just doing the entire countertop with 2-3 layers of backer board (hardi, durock, perma - whatever). I'm worried that if I make the underlying plywood cutouts too big, the concrete board and skim coat that's unsupported will flex and crack over time...
    Seems like there are downsides to every option I can think of. :shrug:
    Darren
    ~20K gallon freeform w/attached spa
    Pentair 4x160 pump
    Pentair Mastertemp 400K BTU heater
    Intellitouch i7+3 controller
    Intellichlor IC40
    Apr 2013
    Sacramento, CA
    2,769
    Re: Countertop construction
    I would need to think it through but I would support the durarock or whatever around the grills with steel studs.
    I'd have to think through the mechanics of it.
    In short no wood within a couple inches of the grills.
