Thread: Polaris with beach entry
    Feb 2015
    Luling la
    4
    Help, hoping someone can give me some ideas on what they use to keep Polaris or any other pool cleaner from climbing out or getting stuck on the beach entry. Thanks for the help.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris with beach entry
    You need to design the pool so the port (dedicated return) for the hose is located so the Polaris cleans the entire pool and does not go too far up the beach while still reaching the entire deep end. Its a bit art a bit trial and error and a bit experience. The key is port location.
    Feb 2015
    Luling la
    4
    Greatly appreciate the response problem is it's already in. I guess I could cap the existing and tie in to the line behind the pool since that area is grass then move the line down and drill the pool and reset. Was hoping for something that someone uses to put across the beach area. Thanks again!
    Apr 2013
    Sacramento, CA
    2,769
    Is there deck there? You could drill through the pool wall. Not simple but a good pool guy could do it. If deck at the location its problematic.
