Thread: High chlorine level???
    Jan 2016
    Long island NY
    80
    Just did my test. Family member put in shock last week to clear up cloudy while I was away. Now my levels are as followsFC 15.5 CC -0. TA- 100 CYA 55-60 should I lower chlorine level??Thanks!!
    20x40 rectangle, 28,500 gallons, Vinyl liner, Hayward cartridge filter VSP, Hayward aqua connect automation, connected spa with overflow, Hayward heater, automatic cover, TF100 kit
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: High chlorine level???
    What did you test with? Your FC is high, but not dangerously so. Your target is 7 ppm with min of 5 ppm at CYA of 60. Slam level is 24, so you are safe to swim. Let it drift down and you'll be back to normal tomorrow.
    Pool School - Chlorine / CYA Chart
    What is your pH?
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jan 2016
    Long island NY
    80
    Ok cool, tested with my TF100
    I also turned off my SWG. Good idea??
