Results 1 to 12 of 12
Thread: Mess After Vacation
    Apr 2016
    tampa, fl
    15
    Mess After Vacation
    Haven't checked in for a while as pool has been sparkly and clean.. Went on vacation last week and came back to yellow algae on walls in shaded end. There's been a ton of rain here too so that's compounded the problem, I'm sure. Do I need to slam? Is it possible it'd go away without doing that? My numbers:
    FC 2.5
    PH 9
    TA 80
    CH 190
    CYA 65
    I turned the SWG up to 70% from 50. Thanks as usual for any help.
    17K IG Concrete w/hot tub; Hayward: Super Pump 125, Aqua Rite SWG, Navigator Pro, 250k btu heater, Taylor K2006
    Sep 2015
    Dallas Texas
    53
    Re: Mess After Vacation
    Yes, the presence of algae requires a SLAM
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Apr 2016
    tampa, fl
    15
    Thanks very much, I've collected all of the supplies needed for SLAM and will start this evening.
    Any ideas what specifically could've caused the outbreak based on info above? Would heavy rain be enough? Just trying to avoid this again this summer.
    Jun 2015
    Jackson, NJ
    123
    Your chlorine is too low for the CYA level you have. http://www.troublefreepool.com/threa...rine-CYA-Chart
    Your pH is too high period. http://www.bluescience.com/swimming-...to-pool-water/
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I've never seen PH test that can measure 9. It is very important to maintain PH between 7.2 and 7.8 at all times. 7.5 to 7.8 is better for your pool.
    Apr 2016
    tampa, fl
    15
    thats my fault. it tested darker than the highest number on the kit so i put 9. it may be above that, but ive got plenty of acid to bring it down to slam. couple last qs.
    is 2 hours enough time after adding acid to get a proper reading (pump on)?
    does the algae have any effect on giving me a true ph reading?
    since my pump will be running during the slam, is it ok to leave my robot in the pool? i dont have a manual vacuum.
    DFW, TX
    24,497
    30 min should be enough. Algae has no I pact on the PH test. Yes, robot is fine.
    Sep 2015
    Dallas Texas
    53
    Quote Originally Posted by s1njin View Post
    This caused ur issue
    inground
    Cartridge filter
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by ashley79 View Post
    could you please add name of the test kit you use to your signature?
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Apr 2016
    tampa, fl
    15
    added.
    thanks to all for the info.
    Apr 2016
    tampa, fl
    15
    Pools been clear but passed OCLT this morning; went from 24.5 to 23.5 FC. When will PH test be accurate again?
    DFW, TX
    24,497
    Ph test is accurate with FC up to 10 ppm.
