Thread: Pool Builder/Replaster Recommendations LA County, San Fernando Valley
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    I have to re-plaster this year, along with tile and coping, but I'd also like to find out what the cost of re-configuring the shape would be. It is currently a "kidney bean" shape and I'd like it to be a rectangle.
    I'm searching for businesses to do the work through Yelp and Angie's List but I wanted to post here in case some of my "neighbors" here on the forum have had similar work done...?
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    Re: Pool Builder/Replaster Recommendations LA County, San Fernando Valley
    You aren't really "reconfiguring." If you want it to be a rectangle that fits inside your irregularly shaped pool you will go through (slightly) lesser expense. If you want it the same size or bigger, you're essentially demolishing and building new (cost of a new pool build plus costs of demolition of existing pool). I have a friend who was considering "moving" their gunite pool to another part of their yard. I had to explain that there was no "move" only demolish and rebuild.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by Geebot View Post
    Thanks Geebot! That's what I was figuring the answer would be to a "reconfiguration." In fact, I set up an appointment with someone right after posting this and the receptionist said it wouldn't be worth it...
    Patrick
