Thread: ipool (1,300 gallon pool) in need of a heater
    Aug 2016
    snohomish
    5
    I bought a ipool (1,300 gallon pool) to swim (has a harness) but I underestimated Seattle's crappy weather and the pool is way too cold.
    I really only need to heat it for an hour of swim 4 days a week and I do not need it very warm just tolerable cold.
    I have read horrible stories about electric bill on electric heaters; however, I do not have gas on the yard and I dont want to spend thousand on a heat pump.
    1) What is your recommendation to do here?...how bad will be the electric bill hit?
    2) Will a 5 kW 1.89 GPM Smart Spa Electric Spa Water Heater be enough or should I go for the 11 kW 1.89 GPM one?
    3) I was also looking at the CSPAXI11 Comfortzone 11Kw Cspa Electric Spa Heater, is that one better choice?
    3) Is there any recommendation for any other electrical heater in $500's range?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Re: ipool (1,300 gallon pool) in need of a heater
    Is the pool outdoors? Solar blankets are pretty effective at preventing heat loss overnight. I would try that first. Then even if you do still decide to add a heater, the blanket can still be used to retain the heat, lessening the time you need to run the heater.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2016
    snohomish
    5
    Quote Originally Posted by jeffchap View Post
    Thanks for the suggestion. No, there is no sun in Seattle. Literary no sun and especially this summer. I will get the blanket thou but I do need some artificial warming.
