Thread: Calibrating AquaCal Heat Pump
    HI
    I have an AquaCal HeatWave SuperQuiet Heat Pump Model # SQ145. The temperature reads 76 degrees on it today and the pool is about 90 degrees.
    Is there a way to calibrate it?
    Anders
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    Re: Calibrating AquaCal Heat Pump
    Are you sure the display is showing actual water temp and not set point temp?
    Is the pump on and water flowing thru the heater while you are checking the temperature?
    The temp sensors on those type of units generally cant be calibrated if it really is that far off you will likely have to replace it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
