Thread: Air Bubbles in Return Line
    Question Air Bubbles in Return Line
    Hi,
    I am having a lot of air bubbles in my return lines to the pool. I have a AutoPilot Salt Chlorine Generator (RC 35/22) it is see through and i can see a lot of air in the cell. There are no air bubbles in the pump (when you look through the plastic cover over the basket). I recently had all the lines pressure tested by a pool company and they found no leaks.
    There is a three way valve imedialtely after (in line with ) the salt chlorine generator cell before the water goes into the pool. This three way valve controls which returns get the water. There are 4 returns so you can have two on at a time or leave the valve in the middle and then all 4 returns shoot water out.
    The interesting part is the when I turn the valve all the way over to only use the 2 returns in the steps of the pool no air comes out, when i turn the valve to 50/50 or on the two other returns outside the pool steps the i got a lot of air.
    How is this possible? It is not on the suction side so how can air come into the system. If there is a leak wound water shoot out somewhere?
    Please Help
    Anders
    30'000 Gallon Salt Water
    AutoPilot Digtital Nano Salt Water Chlorine Generator
    AquaCal Heat Pump
    CoPilot Ozonator
    Jandy 1.5 HP Model#PHPM1.5
    Candy Pool Filter Model#DEV48
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,680
    Re: Air Bubbles in Return Line
    Salt Water Chlorine Generator's generate bubbles when on. See if the bubbles stop when your Generator is not on (but the pump is on). If no bubbles -- no worries.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,565
    Anders,
    I suspect that when you have all four returns open the flow is less and that allows you to see the bubbles easier. When you have the return water only going to two of your returns the pressure goes up and makes it harder to see the bubbles.
    As mknauss says, if the bubbles are only there when the SWG is producing chlorine, then you have nothing to worry about. I'm not familiar with your specific SWG, but most of them turn on and off every few minutes based upon the percentage of output you it set for.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Agreed. My SWG makes plenty of bubbles. Turn it off and see what happens. The other two returns might be capturing the bubbles somewhere and will give a big bubble sooner or later.
    Aug 2016
    San Antonio
    1
    I am absolutely brand new to pools and most of this is Greek to me. However just after we bought the house our pool started to blow bubbles out the jets. Not sure if that's what you are talking about or not. I found out my water level was to low and the skimmers were sucking air. Once I got the water level back up where it was suppose to be it quit. Again brand new but thought this might help.
    New pool owner. Bought a home with a 18,000 gal in ground salt water concrete?? Pentair intellichlor and cartridge filter. I Know absolutely nothing about pools!
