Results 1 to 8 of 8
Thread: Pump Surging Or Pulsing
    I have a Hayward Power-Flo Matrix 1hp.
    My pump has started surging or pulsing lately. I can tell because of the sound, and the hoses are always moving back and forth as if there is a slight pause in the pressure.
    Is this normal or should my pressure always be the same coming from my pump?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,171
    Re: Pump Surging Or Pulsing
    It's not normal. Any bubbles in the strainer basket or noises in the skimmer? Does the skimmer weir move up and down smoothly?
    Yes. There is a constant flow of water to the skimmer / pump.
    I'm wondering if I have an air leak in my pump somewhere. When I turn the pump off water leaks from around the pump skimmer housing.
    I changed all of the seals a few weeks ago, and the skimmer lid is secure.
    SW Indiana
    9,171
    Quote Originally Posted by riverwalker76
    You probably do have an air leak where the water is leaking. Where exactly is the water coming from?
    The water is coming from the seal in between the Basket housing and the Pump Cover.
    I replaced that o-ring when I replaced the others a few weeks ago, but for some reason it's still leaking.
    SW Indiana
    9,171
    I'd try lubricating the O-ring with pool lube. Then make sure the lid is tight.
    Nov 2013
    Dallas, TX
    13
    thanks for the terrific forum; my brain gets bigger with every visit
    My pump was surging this morning; we had a nice old storm last night in Dallas and a crud load of leaves coughed up all over the pool and yard.
    So i suspected a clog in the plumbing - anyway here are the steps (after reading various posts and my pump manual) and things seem ok for now - touch wood:
    0) turned off pump
    1) emptied skimmers and vacuum filler bag - everything was chockers full of leaves
    2) turned off the circuit breaker to the pump (i have a freeze protector so merely switching it off at the timer doesn't guarantee)
    3) removed the pump filter cover at the pump and emptied the pump basket and also sprayed out the **** inside it with a hose to the outside of the basket - probably about 30% lined with small leaf fragments
    4) put my hand into the pump toward the impeller to see if i could touch any organic matter - none
    5) separated the o-ring gasket from the cover and used a rag to clean the perimeter of the cover (a tiny bit of crud) - inspected and re-positioned gasket
    6) replaced basket - replaced cover
    7) opened air bleed valve on DE filter
    8) turned on circuit breaker - turned on pump
    9) waited for water to come out of filter air bleed valve (took 2 mins)
    10) closed off valve - it appeared i still had the issue but to a lesser degree - pulsing was at longer intervals and not as dramatic
    11) added water for 15 minutes to the pool
    12) problem went away after 20 minutes and hasn't returned 4 hours later - steady stream from my pool descent and spa fountain now
    hope that was helpful to some other newbie
    In Ground Pool and Spa (plaster); 20,000 Gallons (39' * 14' * 5')
    Zodiac Pump Motor 2.5hp Model PHPM2.5
    Jandy DE Filter Model DEL60; Jandy LX Heater
    Aqua Pure SWG Model PLC1400
    Intermatic Mechanical Timer w/ freeze protector
    Nov 2013
    Dallas, TX
    13
    quick update - looks like adding water was the key to my issue here
    normal to need to top off 15 minutes of water every 10 days or so - over winter?
