Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: ROFL: Rio Olympic pool technicians don't frequent TFP
    May 2015
    Ten Mile, TN
    74
    Rio spokesman Mario Andrada told The Associated Press that the pool at the Maria Lenk Aquatic Center changed hues due to "a proliferation of algae" caused by heat and lack of wind at the outdoor venue.
    - Source NBC (link)
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
    Triplejnj's Avatar
    May 2015
    Jackson, NJ
    35
    Re: ROFL: Rio Olympic pool technicians don't frequent TFP
    LOL.. just read the same article. Break out the bleach folks, time for a SLAM!
    Tom
    16k freeform IG vinyl w/ waterfall feature| Hayward 2hp pump, 300lb sand filter, 250k btu heater | AquaRite SWG | Installed October, 2014
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Wonder what else is festering in there?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Wow....clearly the pool tech isn't a TFP member
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Jul 2016
    Whitesboro, TX
    85
    Can you imagine trying to slam a pool like that? That's a lot of bleach! HA!
    22' Round x 52" deep Coleman AGP, 12,500 gallons. Filled 5-1-16. XtremePowerUSA 4500 GPH 19" Sand Filter w/1.5 HP Pump. Hayward Dyna-Skim In The Wall Skimmer. Hard Plumbed w/2" PVC. PVC Aerator. Pentair Kreepy Krauly Lil Shark Above Ground Pool Cleaner. Whitesboro, TX (North Texas). Taylor K-2006 Test Kit Comp Chorine FAS-DPD. Use The Pool Math App By Trouble Free Pool For Logging.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Rio spokesman Mario Andrada said the green was caused "by a proliferation of algae."
    Ya think?
    Officials said that the water was tested and posed no risks to athletes.
    Really?
    Green Olympics: Algae turns Rio pool a strange color | Fox News
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    backhoed's Avatar
    Jul 2016
    Rockaway, NJ
    12
    why only one pool then? hmmmmm
    18 ft above ground round
    Hayward DE filter/ 1.5 hp pump
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by backhoed View Post
    the other was cooler and I hear now it's turning green too
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    More like proliferation of idiots. You would think they would find some people that know how to take care of pools in a nation that has resorts with pools and such.
    njboater74's Avatar
    Aug 2015
    Lawrenceville, NJ
    18
    I don't understand, I saw them add like 5 or 6 pucks last week.
    33k gallon, 40x20 IG Vinyl, Hayward sand filter, Hayward pump
    Hayward multiport valve, TF-100 Test Kit.
    May 2015
    Ten Mile, TN
    74
    Update from the Wall St Journal:
    Yesterday mid-afternoon there was a sudden decrease in the alkalinity of the pool,” said Mario Andrada, spokesman for the Rio 2016 Organizing Committee. “Obviously, the people in charge of maintaining the pool and of checking could and should have done more intensive tests.”Andrada said the pool color would get back to normal “very shortly.” However, he added, Wednesday’s rain in Rio was complicating things.
    Several possible explanations emerged Wednesday, though not all seemed to fit together.
    FINA, swimming and diving’s world governing body, said the change occurred, because “the water tanks ran out of some of the chemicals used in the water-treatment process. As a result the pH level of the water was outside the usual range, causing the discoloration.” FINA also added that its sport medicine committee had deemed the water safe for competition.
    Tests, he said, had confirmed there was “absolutely no risk, no effect for athletes who will compete in the pool.”
    A pool consultant working for the Rio Organizing Committee said the change had come about as a result of workers seeking to make a last-minute improvement to the color and clarity of the water. The person added that certain unknown components of the city water that goes into the pool after treatment might have been responsible for the imbalance.
    “If you bake a cake with too much flour,” the person said, “it’s going to turn out bad.”
    Typically, the person added, the problem could be solved within 24 hours. Every drop of water in the Olympic diving pool is turned over and run through the filtration system in six hours.
    Jun 2015
    Jackson, NJ
    123
    Day 2, the other begins to fall. Somebody pass them a few cases of bleach please. And a TF-100 !
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
    May 2015
    Ten Mile, TN
    74
    And Brush, brush, brush (just went through this)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    It boggles my mind that the pool keepers at an Olympic Venue could EVER let something like this happen.
    Divin Dave,
    Probably adding phosphate remover and copper algaecide as we speak.
    They test the water once a week with test strips. What could possibly go wrong?
    I like how they cite "lack of wind" as a contributing factor.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,232
    Someone should tell them that their sand in the filters "has gone bad" and they should definitely change their sand.....
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I did see a comment somewhere in the news that said they probably need to clean the filter. Make sure you turn off the pump before you turn the lever you backwash! It'll be clear in no time now!
    May 2015
    Ten Mile, TN
    74
    Quote Originally Posted by Divin Dave View Post
    The report is they ran out of chlorine. Now I read that they are running out of people food
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Now I understand how my pool does so well with so little Chlorine. It's very windy here but I never put 2 and 2 together like that. Thank you wind.
    Essential Links:
  20. Back To Top    #20
    May 2015
    Ten Mile, TN
    74
    Quote Originally Posted by PAGirl View Post
    Then there is the nearby bay - see link
