Thread: valve handle positions for on or off.
    May 2016
    Dearborn/mi
    2
    I'm having a similar problem.
    My biggest issue is I can't turn the handle of the skimmer(is closed)
    I don't want to force it and break something else.
    i was planning to remove the screw and spray W-40.
    I still don't know which way the valves should face.
    tony d
    Tony de Lara
    Jun 2014
    15,221
    Re: valve handle positions for on or off.
    Hello Tony and welcome to TFP. Looks like your post was separated from another thread. I don't see any descriptions for your system or valve(s). Can you upload a quick pic of the valve you are concerned about? Also, I would not use WD-40 on any pool-related products, seals, etc. The chemicals in household lubricants can be corrosive to pool seals later.
