Results 1 to 7 of 7
Thread: PH keeps rising
    Jul 2016
    Boston, MA
    18
    PH keeps rising
    Can someone help me? All my levels seem to be normal, but my PH keeps rising to 8.0 or higher every couple of days.
    Pool has been crystal clear since I found this site, learned how to slam and got the CC to 0. Haven't had any issues except the PH.
    Currently pool levels are:
    CYA -30
    TA-180
    PH-8.0
    FC-.5
    Is this normal for it to keep going this high?
    Thanks
    Inground, Vinyl Liner, 27,500 gallon, Hayward Sand Filter S-220T older, New Hayward SP2610X15 Super Pump 1.5HP,
    Jun 2014
    15,189
    Re: PH keeps rising
    Looks like your TA is a bit elevated which will allow pH to rise faster. You could use some help from the TFP Pool School - Lower Total Alkalinity page. Try lowering that TA down to around 80 or so and see how that works for you.
    Also, if your FC is truly 0.5, that's too low. You should increase that ASAP to about 4-5ppm to prevent an algae bloom from starting. Hope that helps.
    Jul 2016
    Boston, MA
    18
    Re: PH keeps rising
    Quote Originally Posted by Texas Splash View Post
    I thought I should keep FC at 2 or below as that is what it said in the Taylor kit. Is 4-5 more recommended for me because it takes into consideration the CYA? So 4-5 is ok to swim in? I will add a gallon right now. I have kept it at 2 or under since I ended my slamming over a month ago. I don't want to go through that again!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: PH keeps rising
    Does this chart make sense to you? Pool School - Chlorine / CYA Chart
    If not please ask questions.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    Boston, MA
    18
    Re: PH keeps rising
    Sorry, but one other question I forgot to ask, I added my sodium bisulfate to get the PH down this morning. About 2 hours ago. Is it safe to add my gallon of chlorine now or should I wait?
    Jun 2014
    15,189
    Re: PH keeps rising
    Yes, please follow the levels listed on the Pool School - Chlorine / CYA Chart. We always balance FC with the current CYA as they work together. The water is safe to swim in as long as you don't exceed the SLAM/Shock FC level based on your current CYA.
    You can add the bleach now.
    Jul 2016
    Boston, MA
    18
    Re: PH keeps rising
    Quote Originally Posted by Mr Bruce View Post
    I only referred to that when I was slamming. I haven't looked at it since. Was going off the Taylor Kit pamphlet. Yes that answers my FC question thanks for pointing that out.
    Thanks for your help. I will do that and take care of the TA and see if that helps.
