Results 1 to 9 of 9
Thread: Downside to Borates?
    Aug 2016
    Cincinnati, Oh
    48
    Perhaps this should be in the advanced section. I'm thinking ahead and one of my chief complaints is the harshness of our pool water. Understandably the numbers were out of whack and I'm on the verge of good numbers and clear, algae free water. Last night I hopped into the pool for a cool off and noted the water did feel much better but I'm never satisfied and since we have a softener in the house I'm spoiled. I read the thread on Borates - Why and How, it *sounds* like Borates would create a feeling similar to softened water, correct? Additionally, there are other benefits but are there any reasons why it might not be for me?
    Thanks
    10,350 In-Ground Vinyl
    Sand filter, 1.5 Pentair Pinnacle
    Municipal water source
    Liquidator
    K2006
    May 2015
    Land O Lakes, FL
    527
    Re: Downside to Borates?
    This post covers it well:
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Phillip, I would say that borates plus salt and lower calcium combined makes water feel softer
    So you may wish to add salt as well.
    Also, just so you know, i top up my water from a dual softener system plumbed to my pool spigot. In my case, I do it to avoid metals. But in your case, you could do it for the feel of the water...but you've gotta watch your capacity or have a dual system set up to handle regeneration.
    That's why my water is super soft...people used to swg water even comment that mine is "inexplicably softer" I am swg, plus borates, plus softened water.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    jdoty1977's Avatar
    May 2016
    Little Elm TX
    38
    Not sure if this is good or bad, but most of the wasps that used to land on the surface to drink and harass me drown and end up in the skimmer now. Surface tension is just to low for them to float I suppose.
    2016 Build: 20x30 15K Gal-IG Gunite, #4 Steel Tanning Ledge, Bubbler, Flagstone Coping, Stamped Concrete Deck, Jump Rock, Rock Waterfall, CLI Majestic Isle Pebble Finish, 3 Multi-Color LED lights, Ozone-DEL Eclipse 10, Empty Inline Tab Feeder, 2 HP Jandy Pro Series ePump with SVRS, 2 Skimmers, 6 Returns, 2 drains, 1 Cleaner Return, Jandy CV Filter 460 SF, Dolphin Nautilus+, iAqualink RS Automation, Borates, Test Kit Taylor k2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Yes, borates around 50 ppm and salt @2000+ ppm can improve the water feel. As for lower CH that is possible but CH doesn't always make the water feel hard, TA also contributes. It is more probable that maintaining your CSI between -0.3 and 0 will improve the water feel. PoolMath will calculate your CSI for you after you enter all of your test results.
    30,411
    That's very interesting.......and a possible side benefit. I guess it may make debris sink a little quicker, too, so that might negate the "wasp" benefit.
    Is there enough difference so that you can actually see the water not "bead up" as it does on many surfaces?
    jdoty1977's Avatar
    May 2016
    Little Elm TX
    38
    Have to check that later because it never beaded up on the flagstone or unsealed concrete around the pool as it is a fairly porous material. I will say the meniscus in the testing tubes is far smaller which is why I think the surface tension is less.
    Bananimal's Avatar
    Aug 2016
    Madisonville, LA
    51
    I was wondering as well.....I'm going to be adding borates to my water very soon. Is aeration the only option to raise pH once borates are added?
    Installed 7/10/2016 : 18.3K gal. : IG Plaster : 3.5' - 6.5' : Integrated Spa
    Pentair WhisperFlo Pump, 1.5 HP : Century Centurion Booster Pump, 3/4 HP
    Pentair 420 sqft. Cartridge Filter : Pentair Inline Rainbow TriChlorinator
    Pentair EasyTouch Pool/Spa 8 : Pentair IC60 SWG : Pentair Intellibrite 5 Spa Lights x 2
    Pentair Kreepy Krawly Legend Pressure Side Cleaner : Taylor K-2006C Test Kit
    Aug 2016
    Cincinnati, Oh
    48
    Thanks for the input, I did read the Borates thread. I reread it to make sure I wasn't missing anything. The Cons that were listed (cost, risk to animals) are not a something we'd need to worry about. I was looking for additional input from people who had added Borates. The comment about the wasps is interesting, we have a lot of wasps and carpenter bees and spiders and crickets. Every time I get into the pool I have to vacuum dozens of crickets and spiders off the floor before I can really enjoy the pool. Our pool is small so it takes all of 5 minutes to do by hand. A few dozen more wasps and bees would not be an inconvenience for me and hey, dead wasps right?
    This is something I'm considering for next season, gotta get the chemistry straight first. Thanks
    Liquidator
    K2006
