So, when can I use a vacuum?
Titan7
791
Peoria, AZ
Pebble plaster 2 weeks old, been brushing 2x per day. Not much dust that i can see but on the bottom is seems like i am just brushing old dust around. So continue 2x per day for another 2 wks then vacuum?
Also when do i clean the filter? i have the largest Jandy filter they make.
Thx
The vacuum my PB gave us has plastic wheels. The startup guy put it in the pool exactly 1 week after plaster. It was fine. I used it last week (plaster 2 weeks old) because I had so much dirt in the pool from them filling and grading.
Walmart and Lowe's actually have brush head vacuum heads for really cheap if you want to get one.
Yes, there is a diverter valve to divert flow between skimmer and drain. I agree with Brian that it is fine to launch the pool cleaner in a pebble pool.
