Thread: My First TF-100 Reading
    TraceingPaper's Avatar
    Jul 2016
    Pittsville/WI
    31
    So my results are:
    FC 10.5
    CC 0
    TC 10.5
    pH 7.2
    TA 130
    CH 200
    CYA 30
    I've been adding about 1/2c 12.5% bleach daily until my test kit came, so my best guess is that's why it's so high, so until it gets closer to a 4 I will then decide if I should adjust my pH, (a) is that correct? I have iron in my water so maybe I should keep it around (b) 7.2? Also, (c) is my TA too high & should I do something to lower that? My pool will be closing for the winter so idk if it's worth worrying about before doing so. (d) At this point in time should I do the ONCLT? So many questions I know... Thank you.
    ps: also thank you for the recommended speed stir! I'm very happy I splurged and got it!
    Also, I bought the pressure gauge as mine didn't work. This one was covered in the oily substance that is inside it, with large air bubbles, the liquid is coming out of the rubber stopper at the top. Is this worth worrying about or will it still work?
    AG 16,700gal Aquarian Pacific 27'x52" round vinyl
    Hayward Power-Flo Matrix 1.5hp Pump
    Hayward Pro Series High Rate 200# Sand Filter #S210T
    TF-100 Test Kit & SpeedStir
    Well Water Filled... Ask me how I turned my BROWN pool BLUE!
    30,407
    Re: My First TF-100 Reading
    Assuming your water is clear, I would do little to that pool. Don't mess with TA unless your pH gets difficult to keep low (7.2 is good to keep the iron dissolved.....good thinking.
    You can do an OCLT anytime.....I think you'll pass.
    Jul 2016
    Pittsville/WI
    31
    Thanks for the quick response! Water is clear!
